jdbower
Platinum Member
Using a solid metal conduit should also help isolate things a bit better - plus it'll prevent EMI between the conduits (although in theory the foil lining in the CAT5 should do that well enough).
My guess is that the restrictions on gas, water and sewer stem more from leaks than anything else - a spark near a leaking gas pipe is bad, as is water leaking into electric or sewer into water. Electric doesn't leak nearly as much
