Another Ford starter issue
   / Another Ford starter issue #11
I've got a Ford 250c (50 hp 3 cylinder diesel) That has a starter issue. When its colder outside (in the 40's) The starter spins the engine for a few revolutions and then just whirs. If I plug it in and heat it up it usually starts without issues or at most will do the same thing a couple of times and then the 3rd time I try it starts. The problem seems related to how hard it is to turn over.
I'd rather not replace the whole starter if its just a solenoid or something needs replaced.
"Whiring" is usually caused by the drive clutch on the starter drive slipping. Remove the starter and replace the starter drive.
   / Another Ford starter issue #12
LouNY is on the money. The starter drive is dirty and/or drive which doesn't allow the bendix to fully engage in the ring gear. When it is colder, the problem is exasperated as whatever lubes is left doesn't do much.
Also, the 3 cylinder diesel uses an intake heater, which, is not great. No glow plugs.
   / Another Ford starter issue #13
The starter issue is unrelated to a lack of glow plugs. Thermostart is an effective cold start aid for anyone that understands how to use it. A block heater is an even better option.
Lou has good advise, I do not mean to imply otherwise.
   / Another Ford starter issue #14
Agree with Lou. When in doubt, I put a voltmeter lead on the starter stud...the end of the copper stud protruding out the front of the starter proper, not the solenoid. I put the other lead on the aluminum case of the starter proper. Set to 20v range and have someone attempt to start it while you monitor.
If you aren't getting 10V at the starter where measuring, since you have a new (fully charged you checked yourself) battery, your problem is a high resistance somewhere in your interconnect cabling. Do not forget to check where the battery negative cable attaches to the tractor proper. If under a starter mounting bolt (which needs to be removed and that interface needs to be cleaned then reinstall the bolt and tighten accordingly) the chances of a bad connection are minimized. If under some other engine/tractor frame bolt, good place for the problem...corrosion.
The copper in the starter proper and copper in the interconnect cabling is the lowest resistance as temperature decreases so this is in your favor (good). CCA of the battery drop with temp drop (bad). Engine resistance per se drops since the steel contracts and interface gaps get larger (good). Engine oil gets thick and is a big deal (bad) if in a cold climate and you aren't using a good, clean, cold weather rated oil....like Shell Rotella T 5W-40 full synthetic (top of my list). Even using their dino 15w-40 can thicken up on you, and if using straight 30w or higher....forget it (really bad). If you get a measurable starting advantage from any crankcase heater, you probably have oil fighting you....and old dirty, black, diesel oil, is a culprit. If you find a viscosity chart for engine oils vs temp, you will find that going cold the viscosity increases at a very fast rate as the temp. drops.
Last is engine compression. Compression is what generates the heat that explodes the diesel mist in the cylinder. Low compression or slow engine rpms during cranking can prevent this. If, when you get it to light off, if you see a lot of white smoke that takes a few minutes to clear out (not half a minute or so at worst) you have a sign of a cold cylinder and condensation from unburned diesel due to low compression caused by worn rings, or slow cranking rpms.
I bought a used 3000 and fought the idea that compression was my starting problem for years (had no diesel compression tester) until I had exhausted every trick I could think of and did an inframe. The pistons were ruined. Top ring slot was worn completely out. Had to have new pistons along with the other normal O.H. parts.
Thermostart, I will say, is a must for cold starting on older tractors with "low compression" and really cold temps. Even down here in N. Tx. when I had a low compression tractor, I had to have it and then some to get a light off. As of today, none of my Fords require TS on the coldest days here in N. Tx.
TS takes about 30 seconds for the self contained coil to turn a hot orange color, heat from such causes the diesel fuel plug contained therein, to unseat and let diesel dribble down over thse hot coil wires igniting the droplets into glowing embers. Rolling the starter switch on over to Start, which also keeps the TS working, the engine rpms suck the glowing embers into the combustion chamber igniting the diesel mist in the combustion chamber. The colder the temp, the longer the TS process.
   / Another Ford starter issue #15
either your ring gear has some rounded teeth on it, or the clutch on your starter drive is weak.. if you remove the starter to inspect the ring gear, try spinning the drive gear on the starter with your finger, if it spins in the free wheeling direction easily,then the clutch is worn,you will need a new starter drive
2008 IC Corporation PB205 Bus, VIN # 4DRBVAANX8A506494 (A51572)
2008 IC...
2023 DONDI DBR/75 S LOT NUMBER 54 (A53084)
2023 DONDI DBR/75...
WEILER B670 FELLER BUNCHER (A51246)
WEILER B670 FELLER...
2019 KOMATSU D51PX-24 CRAWLER DOZER (A51246)
2019 KOMATSU...
2008 JOHN DEERE 6330 LOT NUMBER 98 (A53084)
2008 JOHN DEERE...
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
