Oil & Fuel another fuel leak ?
   / another fuel leak ? #1
tonyw
NC
YM1401d
I have a 1401d which has recently developed a leak somewhere around the filter bowl. It appears to be coming from the shut-off switch, but there is also a little leakage at the fuel line connections to the bowl/filter. Could there be a seal gone bad at the shut-off? If so, would I have to replace the entire fuel shut-off assembly?
Also, this is probably a dumb question, but
would high temperatures have anything to do with the leaking? I recently built a small pole barn to store the tractor; it has hardly any ventilation--and it's been fairly hot here in recent weeks.
Tonyw
   / another fuel leak ? #2
I doubt it is any hotter than the heat comming off the engine while working it.
Soundguy
<font color=blue>"would high temperatures have anything to do with the leaking? I recently built a small pole barn to store the tractor; it has hardly any ventilation--and it's been fairly hot here in recent weeks. "
   / another fuel leak ? #4
Also check the hoses in/out clamps and connections. I had one start to leak like that and it was just a loose hose clamp.
Jim
Thanks, everybody, for the help! I'll check it out tonight--and hopefully, stop the leak.
I'll get back with what I find.
Thanks again!
tony w
BESTWAY AG VSK50 LOT NUMBER 80 (A53084)
BESTWAY AG VSK50...
1985 Ford Ltl9000 Tender Truck (A53472)
1985 Ford Ltl9000...
2025 New/Unused LandHero 1 in Air Impact Wrench (A51573)
2025 New/Unused...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A53472)
PENDING SELLER...
2001 HEIL PNEUMATIC CEMENT TRAILER (A52576)
2001 HEIL...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
