Another how much water in tire??
   / Another how much water in tire?? #1
mattman
ElDorado,AR
Kioti DK 35
I filled my tires with 1 gallon of antifreeze and I don't know how much water. I can't find a chart with my tire size.
My tire size is 43x16x20 R-4's. Does anyone have the gallons for this tire filled at the 12 o'clock position??
   / Another how much water in tire?? #2
  • HydroFlationTable_AGTires.pdf
   / Another how much water in tire?? #3
One gallon of antifreeze isn't going to do much if you dilute it with a lot of water. There are tables on what sort of freeze protection you can expect with different types of antifreeze but typically you only dilute 3 or 4 to one at most to maintain -20F antifreeze protection.
It raley gets in the teen's around here. If it does it will warm back up the next day. Usually the 20's is as low as we go and that does not last long. Alot of folks don't even put antifreeze in their tires. I wanted a little to help keep the rim from possibly rusting.
2016 Ford F-550 4x4 Ext. Cab Service Truck (A53422)
2016 Ford F-550...
CFG Industrial QK16R (A53316)
CFG Industrial...
John Deere 6145M (A53314)
John Deere 6145M...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A54811)
2019 Caterpillar...
UNUSED Wheeled Dump Hopper (A47477)
UNUSED Wheeled...
16FT box truck (A53422)
16FT box truck...
