284 International
Veteran Member
- Joined
- Jun 28, 2010
- Messages
- 1,464
- Tractor
- International Harvester 284
Looking at the diagrams, it appears the fuel line comes out the bottom of the tank to the fuel filter and bowl, then to a lift pump that feeds the injection pump. I think there is a vent tube that vents the fuel bowl going to the top of the fuel tank, and then a return line beside it from the injectors.
Were it mine, I would get a fuel jug or container equal to the capacity of the fuel in the tank that I could then fill with the fuel line (so maybe having a funnel or some extra fuel line or whatever was required). Pull the fuel line off the filter bowl. If it doesn't drain, stick a wire up in there and root around until it will flow. It will likely plug again, just repeat the process until the tank is empty.
Then remove and clean the tank thoroughly, probably with a spray carburetor cleaner or something, and flush the tank until all traces of the gunk plugging it up are gone. Reattach the tank and lines, put in a new filter, fill with fresh, clean fuel, and go to work. I'd look into a filter funnel or strainer of some sort if the neck of the fuel tank doesn't have one already.
