3-Point Hitch Another L3700 with Jerky lift
   / Another L3700 with Jerky lift #51
I recently did a video on this and the work around options Kubota Jerky Three Point Fixed??? MAYBE .....?!?!? - YouTube
Dave, one thing this scheme will for sure do because of the fact you now have more back pressure in the system because of the restriction you have added in the form of the "diverter valve" is a higher running fluid temprature. Take your temp gun and make some long term measurements of fluid temp with the diverter valve opened all the way towards the power beyond port (lowest restriction) and take some measurements with the diverter valve diverting some of the flow. You need to do this over a long term. Whether this is enough of a tenprature rise to be significant, I don't know. But there will be some temp rise by definition because you have added more restriction to the fluid flow path which raises temp.
I solved the 3pt. jerky hitch problem on my Kubota L3400 by trading it in on my Kioti. problem solved once and for all. I spent a lot of time on the phone with dealers and finally the Kubota regional rep, and the bottom line was and IS, if you wanted a Grand L and its smooth 3pt hitch you should have bought a Grand L. The "Standard L" series 3pt hitch works just like Kubota designed it to work (jerky) and it is not a defect, it just is what it is. To use an old cliche.
Dave this is a pretty old thread and an old can of worms you have reopened there fella.
2014 FREIGHTLINER CASCADIA SLEEPER (A54313)
2014 FREIGHTLINER...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
2017 DRAGON 150 BBL ALUMINUM TRAILER (A53843)
2017 DRAGON 150...
2011 New Holland B95B Cab MFWD Loader Backhoe (A53473)
2011 New Holland...
2017 Ford F-250 Enclosed Service Truck (A53422)
2017 Ford F-250...
