Another plumbing mystery.
   / Another plumbing mystery. #41
That's right and it never required a back hoe in my back yard! :D Of course a back hoe in my back yard on Christmas morning or Father's Day _might_ be a whole different story.:D
Anyway, he snaked the vent stack and that solved the problem, but even now I don't think it was the vent. My wife said each time he snaked the vent stack he came up with hair and soap residue and finally he came up with a huge wad of hair and the gurgling stopped. I don't see how there could be hair and soap in the vent stack. I'm guessing the snake went past the vent stack into a partially clogged drain line.
George, when you first flush a toilet, the water rushes in and pressurizes the drain, pushing air up the stack. If there was a ball of hair in the drain, it could have been pushed back up the stack and partially plugged it. After the stack is plugged, the air would flow in and out from the path of least resistance, your shower drain. Even if the hair was not physically in the stack, it could have been just below the stack and moving to cover it with the inrush from the commode.
Good point Jim. Glad I went into medicine, this plumbing business is beyond me. And speaking of similar things, I have a friend who is a carpenter. I've hired him to put some steps down from the porch on my cabin. I just never got around to it. Anyway, I watched him for a while as he calculated the stringer cuts and cut them out. I'd have made a big mess of that! He made it look easy and they came out perfect.
   / Another plumbing mystery. #43
Bingo!
   / Another plumbing mystery. #44
Jim,
I don't believe the ball of hair would be pushed back if the drain is vented properly. Of course there's plenty of plumbing around that wasn't done properly.
Anyway, glad the OP got his problem fixed and no major work was required.
Pops
   / Another plumbing mystery. #45
Jim,
Pops
I think it will depend on where the shower drain, vent stack and toilet are in line...
if the toilet is after the shower, then the vent then the sink...
anyway-- as you say the problem is solved...
J
   / Another plumbing mystery. #46
Jim,
Pops
If the drain line was plugged at some point, could have been a long time ago, I was wondering if the hairball could have floated up and got stranded (good pun) somewhere as the water seeped away?
Hair and the soap scum it catches are about the worst enemy of drains I think - aside from the stupid stuff that should never be there to begin with.
Dave.
   / Another plumbing mystery. #47
Dave.
stupid stuff..
I think that is covered here: Stupid People Doing Stupid Stuff | stupidstuffbooks.com
J
   / Another plumbing mystery. #48
J
Toilet, shower, sink should all have their own vent. The vents can be tied together overhead, but each drain needs to be vented.
   / Another plumbing mystery. #49
One day at work the yard man asked how to clear a stopped up drain. Told him to take a towel wrap around the water hose and have wife turn on the water as he held the hose in the commode. Next morning could tell he was mad at us and me so asked what the problem was. he said he did as we mentioned. water was running good into the commode when his wife outside under the valley of the roof started to scream at him. The water filled up the vent pipe ran down on her and then he removed the towel from the commode getting a bath. water from the commode and then the hose. Never did find out what the blockage was or was it cleared.
ken
   / Another plumbing mystery. #50
yeah, now that you say that I remember when they did the vents for our master bath they were tied togather in the attic..
J
2007 Saturn Sky Convertible Coupe (A55853)
2007 Saturn Sky...
2007 GMC C8500 Altec DL45TR Insulated Material Handling Digger Derrick Truck (A55852)
2007 GMC C8500...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
Rooster Artwork (A55758)
Rooster Artwork...
16FT box truck (A53422)
16FT box truck...
2017 Ford F-450 Crew Cab Mason Dump Truck (A53422)
2017 Ford F-450...
