3-Point Hitch Another ROPS Strike, Worst One Yet!!!
   / Another ROPS Strike, Worst One Yet!!! #11
Well i...and then we had Carolina Carports come by about a month ago, and 3 Spanish speaking guys popped that up in a very hot afternoon.
How is it anchored to the ground, and how much did it cost? That looks like a great alternative to a pole barn for a lot of things.
   / Another ROPS Strike, Worst One Yet!!! #12
k0ua said:
Well I have been working on the rock pad for months.. Thats where all of those hours got racked up on the ole Kioti...and then we had Carolina Carports come by about a month ago, and 3 Spanish speaking guys popped that up in a very hot afternoon.
James K0UA
Well it looks good. I'm sure you will find more to put in it other than the orange beast!!!
   / Another ROPS Strike, Worst One Yet!!! #13
   / Another ROPS Strike, Worst One Yet!!! #14
I have an 8' door on my barn, so I never think about the ROPS.
Last week, I decided to put my tractor in my garage, (7' door), so I could do some work on the barn. I was backing it into the garage, and I nearly forgot to lower the ROPS.
Probably the main reason I remembered at the last second, is all the posts I read on TBN by those who did not.
I though to myself, that I see how this happens. :thumbsup:
   / Another ROPS Strike, Worst One Yet!!! #15
Building $3200, 12 foot wide by 26 foot long x 10 foot sidewalls . 2 windows $300 extra. Garage door 10 foot wide by 9 foot high $800 . All prices installed. It is staked to the ground with multiple pieces of re-bar with a nut welded on the top end. They will build on footers or slab if you have such. I looked at one on the sales lot, that had been there over 10 years with just the re-bar staking and it hadn't blown away yet. And that includes a couple of nearby tornadoes.
James K0UA
   / Another ROPS Strike, Worst One Yet!!! #16
Just wear a football helmet whenever you go into the danger zone!
   / Another ROPS Strike, Worst One Yet!!! #17
Yeah it will sneek up on you. My little tractor would go in the garage with no problem. But this newer tractor has a lot taller FEL and I smacked the side of the house twice. Luckily it was tall enough to just hit the wood frameworks and not the door itself. Only made a mark in the paint as it. I'm sure there are lots of stories about people hitting their heads and running into low objects.
   / Another ROPS Strike, Worst One Yet!!! #18
James K0UA
I'm going to keep that in mind, I've been using 12x20 tents that last about 5 years but it's starting to look like a flea market out back. Nice thing about your setup is it's also not taxable because it's not a permanent structure. If I built a pole barn that size it would probably add $300/year to my property taxes.
   / Another ROPS Strike, Worst One Yet!!! #19
A new TBN motto "bang your head or you could be dead".
   / Another ROPS Strike, Worst One Yet!!! #20
Sounds like you need a padded rops.
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A56435)
2021 John Deere...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A56436)
2006 Magnolia Dry...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2019 Ford F-550 ETI ETC37IH 37ft Insulated Bucket Truck (A56858)
2019 Ford F-550...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
