Another TC40DA Won't Start Problem - Will Low Hyd. Be Cause?
   / Another TC40DA Won't Start Problem - Will Low Hyd. Be Cause?
FOLLOW-UP: Thanks to all your suggestions. And by listening to my more intelectually gifted friends on this list, I found you all hit the nail on the head.
YES, it was coincidence that I happened to be operating the hydraulic lever at that particular moment.
And NO, I didn't find the problem, but here's what happened to get it running again: I found that the neutral switch circuit had the short and when I jumpered the ends of the wire, it still had a short. So the problem was further up the line. I removed the floor mat and dash panels and checked the entire length of the wiring harness. Since I found out that the wiring harness is made of a soybean-derivative, I really suspected mice damage. BUT, I found no mice damage.
I did find a small indentation on a white wire labeled HM-12. I would have needed a magnifying glass to see if copper had been exposed, it was so small. So I just shrugged and didn't know what to do next.
Out of curiosity, I tried to start it just to see if a loose connector or something else may have happened after all my wiggling of wires and guess what! It started right up and kept on running.
So ....... I don't know if the small indent was actually a grounded short or if I had a loose connection or whatever. The important thing is that it now runs. And thanks to you guys, I had some good advice to work with.
So here's a pat on the back to everyone. :) It sure is nice to know you're out there!
KEG
   / Another TC40DA Won't Start Problem - Will Low Hyd. Be Cause? #12
Good for you for finding it.
Do check out that wire, in that circuit.. re-insulate any scuffed or damaged areas.
Evidentally it was the CB you heard clicking on and off during this time.
Soundguy
2020 CATERPILLAR 306 CR EXCAVATOR (A52709)
2020 CATERPILLAR...
Case-IH 155 Puma (A57148)
Case-IH 155 Puma...
2153 (A58376)
2153 (A58376)
207010 (A55853)
207010 (A55853)
2015 Jeep Compass SUV (A56859)
2015 Jeep Compass...
116 Gallon Poly Fuel Tank W/12V Pump (New/Unused) (A59225)
116 Gallon Poly...
