Another tire loading question...
   / Another tire loading question... #32
Just had my rears filled with water and 3 gallons of RV antifreeze in each. Is Rimguard heavier? Sure. Is it worth the extra money? Dunno cuz I'm not spending the money to find out.
xtn
What size rear tires or how many gallons of H20 + AF to give what temp protection? I have cast wheels to more than cover the 30+ % extra of Rimguard.Thanks,Jim
   / Another tire loading question... #33
Rear tires are 43x16-20 and supposedly will hold about 38 gallons each. Used 3 gallons each of -50 antifreeze. I guess that ought to keep it no worse than slushy down to 27F-ish. That's enough for the Dallas area and garage storage.
Total cost was $57 installed (tractor was already at dealer for other work). Should weigh about 315 lbs per tire. 630 lbs for both tires. That's 9.04 cents per pound. Using more antifreeze would of course up the cost.
If we use rimguard at $2.37 per gallon installed as mentioned above, that's $180 for the same fill. Would be about 410 lbs per tire or 820 lbs total. That's an extra 190 pounds, but it's also 21.9 cents per pound.
I chose the 630 pounds for $57.
In a colder climate requiring more severe freeze protection, Rimguard might quickly become cheaper than adding lots more antifreeze.
RIGID 141 THREADER (A53843)
RIGID 141 THREADER...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
