Another vote to replace trailer tires every 6 years. And get TPMS.
   / Another vote to replace trailer tires every 6 years. And get TPMS. #21
I air my trailer tires to the max pressure. That way, the tire does not flex as much and stays cooler. My trailers that are parked for any length of time are placed on jack stands so the tires don't sit in the same position with weight on them. Tires need to be used to last longer.
I use these also Flatstoppers.com, Vehicle Storage Car Ramps
   / Another vote to replace trailer tires every 6 years. And get TPMS. #22
I use 235/85r16 LT tires on my trailers. I had a six year old tire split open, it was a spare and had never even touched the ground. Several years ago had one tire throw the tread and one to blow out while hauling hay. They were only five years old and looked brand-new. None of these tires were Chinese, all made in the USA.
   / Another vote to replace trailer tires every 6 years. And get TPMS. #23
I have one trailer that rarely gets use. I keep the tires inside the garage out of the sunlight up on a wall mounted rack. By doing that when I need the trailer and have to go through the work of putting them on I'm much more likely to check the pressure first. I also put a spray on protection against UV and ozone that helps keep the tires from drying out.
   / Another vote to replace trailer tires every 6 years. And get TPMS. #24
I bought 4 Greenballs for my 12K Hudson back in spring of 2013. I've made maybe 6 to 8 round trips from Alexandria, Va to Fulton, MS. Round trip distance is about 1620 miles. So total distance travelled was those trips plus annual trips to the inspection station in Virginia, about 5 miles.
Three of the tires still have "whiskers". The fourth blew out on the interstate at speed (about 65) last Thursday. About 1/3 the way to Mississippi. Thankfully a fellow motorist waved me down. About half the tire was gone and I didn't take pictures :( .
An hour wait for AAA, a tip to the guy, roll into town and buy 2 low end tires. My spare (that AAA put on) was even older so that got tossed.
Now I'm a paranoid type guy when it comes to trailering - I've had my "mishaps".
I was driving down to Kings Dominion on I81 in my Dodge B100 van with two of my sons and one of their friends - all 3 between 9 and 12. At speed and in thick traffic a boat trailer in front of me lost a tire and it went airborne, right for my windshield. Traffic to the right of me, traffic to the left, I was stuck in the middle. I floored it and was able to catch the tire above the mirror, it dented the support but nothing broken and I only had to change underwear.
While moving down in 2012
So my routine is every stop I go around and FEEL the tires and axles for heat.
This trip it had been maybe 2 hours since I had checked ALL exterior tires (didn't fell the insiders on my dually) all had been well.
Now maybe the tire picked up a nail or something.
Moral - replace tires every 5 years maybe and now I'm looking for a TPMS system and a new enclosed trailer.
Any recommendations for a TPMS that is good for a trailer?
Funny you mention Fulton Mississippi. I was moving my son to Arkansas the first of the month.
I was delivering his boat to his new home when a tire went on the boat trailer. I pulled off I22 and put the spare on. Got off in Fulton exit ?
At the end of the ramp to the left, there was a walmart. Great I can get two new tires.
Not so great. This walmart has no tire center.
I go back across the interstate to the other side and see a tire store down a side road.
I pull in and had the guy look at the trailer tires. Guy says I don't have 215x ? size tires. I have 205x?. I tell him to put them on.
Real nice people at this place. Jumped right on my boat trailer. I was back on I22 headed to Arkansas within about 30 min
<snip>
Did you mean Nichols Tire Store?
Those guys are great. I had an almost flat inner rear tire on my dually. I took it there and he found that somehow when someone last inflated the tire a tiny pebble had gotten in the valve stem, causing it to S L O W L Y leak. After doing a full water bath leak test of the tire and remounting it (took about a good 20 minutes) he tried to charge me such a miniscule amount I was embarrassed and had to tip heavily.
   / Another vote to replace trailer tires every 6 years. And get TPMS. #26
That's it ! And yes they are Great ! I was traveling from Al. to Arkansas and had this tire issue. They had me (so to speak) and could have charged me big $$$ as I was in need of two tires badly.
I don't carry a lot of cash traveling. They said they didn't take CC or debit. All I had on me was a small amount of cash ,CC and debit card.
I asked if they would take an out of state check. I really didn't think he would, but he said sure... $158.00 and about 30 min. and I was back on the road to Arkansas.
I left them a very good Google review, as they are really great people !
LOT: Tap & Die Set, Hole Saw Set, Snap Ring Plier Set (A59076)
LOT: Tap & Die...
Yard Machines Tiller (A55973)
Yard Machines...
JCB 506-C LOADALL TELEHANDLER (A52708)
JCB 506-C LOADALL...
2015 Ford F-150 Crew Cab Pickup Truck (A56858)
2015 Ford F-150...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
2017 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
