Another well question
   / Another well question #1
Eyecatcher
Pomona Park Florida
Yanmar EX450, Ford 8N/2N, Case 580C backhoe, Massey 185
I have a 4" steel cased well towards the back of my property. It evidenly hasn't been used in a number of years. There was a mobile home there at one time, the well is on my side, the septic system on the neighbors. I'd like to use the well for garden irrigation, but it's 500 feet from my nearest electicity, and there is no pump in the well. I just dropped a string and a weight, and the water table is at 16', and we are really in a dry season. I have a good Multiquip 3" trash pump powered by a 8hp Honda. Specs say the pump will handle 25' of suction lift. Talked to a local well driller the other day, and he advised that if the water table is 16-17' it would work fine. I have no idea how deep the well is.
Here come the questions:
If I put a drop pipe down in the well and plumb the pump to it using PVC and aflexible piece between the pump and the plastic, will this pump enough water for irrigation? If so, should that drop pipe be 3" or 2" ? ID of the casing is 4". How long does that drop pipe need to be? Let's say I drop 20' of 2" pipe in the well, (or would 3" be better?) can I use the 20' suction hose that fits the pump onto that, or would that be too much head?
   / Another well question #2
If your pump will do 25 ft lift then that it is was it can do. If the water drops below 25ft during your draw down then the pump will probably not be able to pull properly. What you don't know is, as you stated, the depth of the well, also you know the static water level is at 16' but the dynamic level may vary greatly from that level. What is your Multiquip pump gpm capability? Most pumps of that nature are not adjustable therefore it will draw water at the spec'ed gpm. If the well recharge rate is less than that, then the dynamic water level will drop. If it drops below the head capability of the pump it will cavitate. Your pump may very well function at more than 25' of lift but not at spec levels. It may also be harder on the pump and will long term damage it.
For the cost involved I would get a section of drop pipe and measure the flow(could just use the pumps spec flow) for a period of time, say 5-10 minutes and then measure the water level in the well. Using a 5 gal water bucket and measuring how long it takes to fill and then doing the math would work but has inherent errors in it as well. Do this at 5-10 minute intervals for however long you would use it for irrigation and determine the wells capacity to stay up with the draw down. Watching it as frequently as I recommend will keep the pump from cavitating and burning up if the water level drops below the pumps lift capability.
Pump is a model QP3TH, rated @396gpm, @ 3600rpm. 25'lift, 95' head max pressure 41.1psi.
Let's talk about draw down. Not far from the well, is a drainage ditch with just a little water in it. I'm assuming that the water level in the ditch and the water level in the well is the water table level. Assuming that the pump will actually move 300 gpm, and knowing that water seeks it's own level, how much draw down would happen in a 4" pipe?
   / Another well question #4
I would have to be one heck of a well to produce 396gpm.
As you can probably tell from my two previous posts, I know very little about wells. I certainly don't need 300 gpm to irrigate my sweet corn. I just assumed that you throttled the pump speed back to get what was a reasonable amount of flow.
   / Another well question #6
You can check the deth of the well by continuing to lower the string with the weight until it hits the bottom of the well. If the water level is 16 ft from the top of the casing mark off the 16 ft and measure the string. A 6 inch casing has about 1 and 1/2 gallons of water per foot so 100 foot of casing would be 150 gallons. A 4" casing would most likely be around 1 gallon +/-.
I use a gas pump for irrigation but not from a well. Pumps have more pushing power than pulling. My pump also has 25'lift of suction but I am not certain that is 25 foot of vertical lift.
You could drop the suction hose down the pipe and fill the hose with water before connecting to the pump, even if your pump is self priming this would aid in getting the flow started. I would then have a short section of discharge hose and just see how long it would pump until the water table drops below the suction hose. You can quickly stop the pump once the flow stops, this way you won't burn the pump up. If your pump has a throttle, once the flow starts you can run it half to 3/4 throttle to slow the GPH down.
My pump has 350 feet to pump/push the water before it gets to my irrigation lines. From this point my sprinkler heads are 75' to 125' away from my main 2" line. I run 5-6 sprinkler heads at 3/4 throttle with a 5hp pump.
Here is a couple of pictures of how I T-ed of the main line.
   / Another well question #7
To wrap up some of the replys and add a few.
1. Determine the depth of the well and install your footvalve about 6' above the bottom. The footvalve goes on the bottom of the drop and is a checkvalve - only allows the water to flow one direction, up the pipe.
2. Install pump and prime - that requires fillin the entire drop pipe and pump with water - usually done through a pipe plug on the pump outlet pipe. All air must be out of the the pump and pipe. I usuially spin the pump a turn or two to be sure there is no air bubble in it.
3. Don't cound on a 26' suction - that is based at sea level and would require a pump and all intake plumbing to be in perfect condition.
4. You say it is a trash pump - those usually move volume but don't produce much pressure. Is there a rating for the pumps "head"? YOu can determine what pressure the pump develops from that. I used to have the conversion formula in my head but it seems to have disappeared this morning.
5. If you are using sprinklers, 30psi is about the lowest pressure you can use for reliable impulse sprinklers IME.
Harry K
   / Another well question #8
One random bit of trivia on wells. The larger your reservoir tank is in your house, the longer your well pump will last. Same holds true with upsizing the motor by a 1/4 hp. If they say 1/2 will do, pick the 3/4HP. Parents well pump lasted 34 years before failing. Otherwise these may only last 12-15 years. It's really not the running of a well pump that does it in but the starting up.
   / Another well question #9
Pump flow ratings are based on some set of conditions. Suction at 25 below the pump will decrease the flow, pressure at the outlet will decrease the flow. Either way, you will not get 396 gpm from your pump.
   / Another well question #10
Yes, and you only have maybe a little more than five feet for drawdown before you lose suction. The twenty five feet will apply to perfect conditions which usually do not happen.
Don't spend a lot of money on the trash pump hookup!:)
   / Another well question #11
Simple version: Pump specs are either/or. Max flow will be at min pressure and vice versa, and both are rated at zero lift (suction height). Actual lift is between static height and the pump. Intake placement should be well off the bottom but remain well below draw-down height. When the latter becomes ~25' or so, cavitation & damage are imminent. The suction hose/pipe might best be sized to the pump's intake port.
I use a HFT 6hp/2" to draw water from the pond with a 2" intake and discarded 1 1/2" fire hoses adapted (barb/clamp) to the slightly different std 1 1/2" (bushed-down) outlet thread. It'll fill a 55 gal drum in < 1min. I get good flow to stands of trees I've planted with 100-150' of the fire hose. This is to flood an area vs running sprinklers etc. Before that I'd use a generator & sump pump in a weighted 5 gal bucket, to draw to the 55-er & dip as needed. That got old fast & I went to the gas pump, though the pond was there & this won't help the OP.
IMO the 8hp/3" pump would not be a good choice if drawing from a 4" well regardless of how deep or how fit that is. Expect it to draw the well down way too quickly and be difficult to predict/control suction with output restrictions. A smaller pressure pump (HFT) & a generator might get you there for a while but would have to be taken to or left on the site.
The 'shallow well/booster' pump (HFT) might work, handier if outlet hoses can be left in place. Trouble with well pumps is that by using split phase motors they demand huge generator capacity to start. A 3k gen might not start a typical 1/2 - 3/4 hp well pump as one would expect by its (motor's) rated amperage, tho' internally (Honda) vs externally regulated (HFT, many others) would do better per rated kw. Too bad the low-flow high-pressure pump I'd recommend for sprinklers doesn't have a gas version. Running electricity way out back would require too heavy a gauge wire ($$) to carry adequate current the distance.
It'd help if we knew the size of the garden to be irrigated, & this mish-mash might be irrelevant considering that, but this could be a tough one to pull off with even the best help. I'll leave the bigger details/explanations to those who've managed using a similarly remote water source. btw: sure hope raccoons don't eat/flatten that corn before the harvest. (BTDT)
   / Another well question #12
What you need to establish is the well's recovery rate (gpm). That is the amount of water that enters the well. This will determine the size of pump you need. If you exceed that size (gpm) the well will drain and burn out your pump. If you use a pump that stays below that level, you will always have water.
The pump will be rated by gpm so get one that is rated below the well recovery rate.
Determining the rate of recovery of the well is simple, measure the depth of the well, then use your mega pump to empty the well. Time the recovery for an hour. "X" number of feet of recovery per hour divided by 60, is "Y" feet per minute. A 4" well has about 2/3 gallon per foot. "Y" feet times 2/3 gives you an approximate gpm inflow. Certainly good enough to determine required pump size. Hope that helps...
   / Another well question #13
I'm up in St. Johns County, my water table runs 2-6'. 16' seems pretty low. ?? Might even be artiasn well with low table.
A 4" casing is pretty big and should be a deeper well. I would drop a weight on a string and find out how deep. (Neighbor's rock well is 600')
For a drop pipe I would use 1 1/4" PVC with a 5' or 10' PVC wellpoint (sold at Ace, HD, Lowes) to filter so sprinklers don't clog. Drop it 30'-40' down. You don't need a foot valve with our conditions.
With that size pump you might need to run multiple hoses even at idle.
I bought a 2' Gas pump at HF for under $200. on sale that does a great job! I used it to wash down a well and to clean out sediment in another and it pumped a lot of water even at a fast idle.
Also well needs to be AT LEAST 100' from septic system to be legal!
2016 John Deer 5075E (A60462)
2016 John Deer...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
2015 Ford Escape SUV (A59231)
2015 Ford Escape...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A61306)
2021 Gehl RT215...
2018 CATERPILLAR 320GC EXCAVATOR (A60429)
2018 CATERPILLAR...
