Anti erosion plant
   / Anti erosion plant
Thanks for the help. This bank is lined by a hay field on the upper side and the barn below. I agree that the wrong ground cover can be nasty, i want to take my time on this and make sure whatever i put in won't cause any headaches later.
   / Anti erosion plant #12
Ground cover is a big help and well worth the trouble if done right. Let us know what you come up with.
   / Anti erosion plant #13
Check into zoysia grass. Needs several hrs of sun. Makes a deep pile rug on the ground and crowds out all other growth. Turns brown in the winter tho. :confused3:
   / Anti erosion plant #14
Crown vetch is a ground cover with many stems coming up from the ground. The juniper is more like one stem with alot of cover on top of the ground. Both are good ground covers just have different attachments to the ground. Vetch is quicker -Hence the states use.
   / Anti erosion plant #15
I have a similar need to cover the back of my pond dam. I'm still researching and haven't identified exactly what to plant yet. I did learn that in several states Crown Vetch was used in the past for erosion control but was found to be invasive and is no longer used. Native warm season grasses (like switchgrass, which was already mentioned) are supposed to be good for erosion control and have incredibly deep root systems. Their roots can be several feet deep.
   / Anti erosion plant #17
And don't forget...Bamboo...
Just kidding.
What do you mean it "was found to be invasive"?
   / Anti erosion plant #19
substitutes for crown vetch - Meadows & Prairies Forum - GardenWeb
not only is crown vetch invasive/aggressive its not really that good of an option for sloped ground. it does grow fast and fill in quickly, which is why it was commonly recommended in the past for slopes. HOwever that time has passed, experience has shown the root system of the crown vetch is not adequate enough to hold the underlying soil. And the vetch itself fills in so much with very few roots that the underlying soil can erode away hidden by the vigorous yet shallow rooted crown vetch. Highway departments no longer promote crown vetch as a good planting for slopes.
Crown vetch or axseed - Invasive species: Minnesota DNR
Ecological Threat:
It is now a serious invader of prairies and dunes.
From PA:
Crown vetch
Trailing crown vetch is a serious management threat to natural areas due to its seeding ability and rapid vegetative spreading by creeping roots. This aggressive exotic is now widespread in Illinois along roadsides and in waste grounds, from where it becomes a serious invader of prairies and dunes.
Crown Vetch
Note do not buy, sell, or plant crown vetch.
From Forest Service:
www.invasive.org/weedcd/pdfs/wow/crown-vetch.pdf
   / Anti erosion plant #20
I would look for a local creeper that's not invasive, blue rug juniper works great and will not encroach outside the area like some grasses will, be mindful of ivy's and such as they quickly take over. I have had good luck with blue rug, stone ground covers, as well as 4" of mulch on banks in the past. Even low growing ground covering flower beds work well, we have some that bloom in the spring, but cannot recall the name,
2014 Ford F-150 Pickup Truck (A55852)
2014 Ford F-150...
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
1985 Miller Wildcat 350-D Welder (A55851)
1985 Miller...
2011 JACK 130BBL (A53843)
2011 JACK 130BBL...
12-Ton Hydraulic Bottle Jack (A55852)
12-Ton Hydraulic...
