Anti Seize question.
   / Anti Seize question. #31
Sorry, I haven't had a chance to reply. Spent the last couple days putting everything back together. Thanks for all the info. I purchased zinc anti seize and marine moly paste from Amazon, I couldn't find this stuff anywhere locally. I used the zinc on the shaft and the moly on the clutch disc splines and clutch release fork shaft. I'm not sure if it will help I sprayed and wiped the inside of the bell housing with PB blaster, thinking maybe it will stop some future rust issues. Most likely it was a waste of my PB. I also opened and polished the shaft housing a few hairs.
Zinc should work well too as zinc helps the lubricant stick. FWIW, as I understand it, the biggest difference in motorcycle oil and automotive oil is that motorcycle oils tend to have higher levels of zinc to help the oil adhere the spinning bits.
2022 Allmond Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2022 Allmond Bros...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
CAT D6C Crawler Dozer (A47477)
CAT D6C Crawler...
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
1983 Case 580D (A47477)
1983 Case 580D...
