Any damage when you try to lift too much?
   / Any damage when you try to lift too much? #11
You can get away with that trick, but what you feel is the bolt stretching beyone it's designed elastic limit. You've weakened it and it may not hold when further tension is put on it. The things are designed to stretch a miniscule amount to maximize friction between threads, but overstretching will do more harm than good. If it's anywhere near critical, use a torque wrench.
   / Any damage when you try to lift too much? #12
Sometimes I can smell hydraulic fluid after the relief valve gives. Is this normal? I would think not, but everything is still working properly. Fluid levels are normal, etc.
   / Any damage when you try to lift too much? #13
Lifting too much can also damage front ends. say you are at max load and you either drop the bucket to quick and stop sudenly or bounce your way down the trail.
Static loads vs. dynamic loads
   / Any damage when you try to lift too much? #14
Sure, you're at max pressure & probably pretty warm fluic temp. and a little fluid always coats the cylinder rod etc.
Now it is time to stop worrying about this and go play.
Andy
Reserved (A53117)
Reserved (A53117)
2018 Vermeer BC1000XL Towable Brush Chipper (A51691)
2018 Vermeer...
2019 Cat 914M Wheel Loader (A52384)
2019 Cat 914M...
2012 INTERNATIONAL DURASTAR 4400 SBA 6X4 WATER TRU (A51247)
2012 INTERNATIONAL...
2008 Ford E-350 Cutaway Box Truck (A51692)
2008 Ford E-350...
FORD 8770 TRACTOR (A51247)
FORD 8770 TRACTOR...
