Any guess on the weight of this load?
   / Any guess on the weight of this load? #21
I am going to guess that it is probabally NOT as heavy as most of the other guesses on here.
Unless the wood was sopping wet
A quick google turned up srpuce @ 28lbs per cubic foot.
ASSUMING it is finished 2x8x12's, the actual dimensions are 1.5" x 7.25" x 12'
Thats about .9 cu ft per board
.9 x 96 x 28 = 2420lbs
EVEN if it was FULL dimension rough cut, it only works out to ~3600lbs for the bottom bundle.
and I'd guess about half as much again for the wood on top. So if it is dimensional, i'd say about 3600lbs, if it is rough cut, I'd say closer to the 5400lbs guesses so far.
Either way, it looks like the trailer AND tow vehichle are adequite enough to handle the load, but I agree with others that you really need to work on how you tie things down:thumbsup:
   / Any guess on the weight of this load? #22
Well said Brokenot.
And I was wrong again. A Durango is a SUV. I was thinking of the equivalent pickup, a Colorado?
Good trailer brakes have two shoes and various other components to make them function. The house trailer axles on the Hurst trailer had one expanding brake band inside the brake drum. In real world conditions, the expanding band system probably (there is that word again) had less than half the braking capacity of good drum brakes.
....Dakota:eek::)
Kyle
   / Any guess on the weight of this load? #25
Thanks for all your safety concerns. I am more interested in weight guesses.
Based on a lumber weight calculator I found online I arrived at about 5400 pounds.
The trailer has two newish 6,000 pound axles with working brakes on each. The tires are almost new. The trailer weighs around 3,000 pounds leaving a 9K capacity. The truck is rated for 9,800 pounds leaving 6,800 capacity above the trailer weight.
The load was well balanced and stopped and cornered without issue. The truck was level before I unhooked the trailer.
I have towed a 7K mini excavator on the same trailer. This load had a greater effect on acceleration. Perhaps the lumber was wet.
So you knew what you were doing all along! So what are you building with those styrafoam filled walls and a big pile of lumber
Building a house. I needed to get the lumber on Friday so we could start today. The concrete has happened over the past months but all the wood in this picture was assembled today. We should use the rest of the trailer load tomorrow. I am picking up 60 sheets of sub flooring in the morning then having a larger load delivered on Tuesday.
   / Any guess on the weight of this load? #29
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
SHOP TOOLS (A58214)
SHOP TOOLS (A58214)
2015 CAT D5K2 LGP (A55272)
2015 CAT D5K2 LGP...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
LOT OF TIN (A58374)
LOT OF TIN (A58374)
