Dealer Any yuchai dozer dealers in CA
   / Any yuchai dozer dealers in CA #11
Very good point Chris.
As an aside, one of the strong selling points about the Yuchai is the category-1 three-point-hitch, which no other dozer has (except for Struck). It was the deal maker for me at the time.
Also, the equipment you find on Craigslist will be well used, guaranteed.
   / Any yuchai dozer dealers in CA #13
As a general rule of thumb, "You get what you pay for".
Most Case 570L-XT's go for much more than that fellows asking price. Either he is very motivated (desperate), or there is something wrong.
What year is it and how many hours on it? I would also want to see maintence and repair records for the past three years - if there aren't any, then I would walk away (they provide evidence of responsible ownership).
   / Any yuchai dozer dealers in CA #14
Just another recommendation for Keno Tractors. I bought a Jinma 454 with Loader and backhoe. Plus I bought the Yuchai Dozer all of it fall to winter of last year.
As Bob stated the 3 point on the Dozer is nice, I have some parts of my property so steep with no turn around that I don't like to use the tractor. I will drag the brush mower behind the dozer and can work the area that way. I probably invested alot into equipment (maybe too much) and think the others advice on a lot of track building can be done for 20k without buying equipment. Plus they are faster with the really heavy equipment and with knowledge of their operators.
Even after I paid to have 2 acres of brush, small trees and 10 ft tall blackberries cleared by a local exacavating company with a 140hp dozer with grinder attachment (they cleared it in 8 hours, at about $1300 cost) I still need to maintain it, hence the purchase of equipment. In addition I planned on carving out a lot of terraces and building a house, doing the excavation and grading myself so buying makes sense at some point.
Unfortunately I was like you, I didn't grow up on a farm, and I don't operate heavy equipment for a living. Luckily my father did operate heavy equipment for a career, and grew up on a farm. I recommend finding a local experienced operator if you don't take the courses as per others recommendations. Follow their advice on how to approach a project. It might save your life or equipment or both. Otherwise it's kind of fun to play on the "toys."
As of now I'm planning to order the Jinma 354 once escrow closes. :)
I hope the loader, box scrapper, and ripper is enough to do the job.
By the way, why is the Jinma on average much heavier than the other name brand tractors? Is more or less weigh better? i was looking at the Kubota and it weighs about 3000 lbs while the Jinma 354 is around 5000 lbs.
   / Any yuchai dozer dealers in CA #16
In my opinion, more weight is better. More weight means more traction, and that means more pulling/pushing power gets transmitted to the ground. A tractor is no good if it just sits and spins its wheels like a car. My Jinma 304 weighs around 5000# with the loader and bush hog mounted and it can still spin a tire on wet grass or dusty hard pan, but it rarely does that and stops spinning immediately if I lock the differential.
Some tractor manufacturers seem to think that they can decrease the weight if they offer 4WD, but that's a god way to break a front axle or differential. You need traction, and traction comes from weight if all else is equal.
Sorry guys but I've decided to buy a used Fermec/MF 650b. :)
It weighs 10,000 lbs and the 4-1 bucket can lift 5500 lbs.
Everything is hydraulically controlled and even comes with quick release pto.
And it's so easy to operate.
and it's 80HP! I just couldn't pass it up.
The Jinma 384 spec is good but this one runs circles around it.
   / Any yuchai dozer dealers in CA #18
Good for you! Much Luck with you new machine. When I was looking everything used was just over/priced old JunK. Much rather have something new that costed less. Good Luck -Ed
New 20ft 5/16in G70 Tie Down Chain (A50323)
New 20ft 5/16in...
2025 Icon Electric Bike (A50324)
2025 Icon Electric...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
2018 Ford Fusion Hybrid Sedan (A50324)
2018 Ford Fusion...
