Anybody build a set of 3 pt discs ?
   / Anybody build a set of 3 pt discs ? #1
milkie62
upstate NY
Kubota M6800,Ford 801,MF 65, Kubota L305
I have a very old set of 8 foot Ford 3 pt hitch discs.Blades are getting pretty worn and need replacing.Been thinking about building a set using either my original frame or using some tube steel and making a set.I can get some new scrap pretty cheap that would fit the bill.Just would need to find a set at a dealer and stop on the weekend to take measurements and pictures.Anybody done this before.I think other than my time,I could save a bundle.
   / Anybody build a set of 3 pt discs ? #3
Discs, bearings etc would be the biggest expense, the cost for steel shouldn't be to high. You should be able to build a good strong frame to suit your area.
I have a Miller 875 plasma cutter and a son that is graduating as a mechanical engineering tech in May.I think I am all set !
   / Anybody build a set of 3 pt discs ? #5
my guess is one would not spend any more on a good used maybe even new, than building it,
now I realize there is a joy in building, but if you need new disks bearings spools and shafts, I would guess just that will run more than the disk would,
for example King Kutter 7.5' Professional Box Frame Disc Harrow 18-24-G-NBF by King Kutter for $1,558.97 : Rural King $1600 for a 7.5 foot tandem disk.
24 blades,
Ok I know I did not take time to find exact matches, but prices is similar,
disks Object moved $40 each X 24 = $960
axels Object moved $106 X 4 = $424
spools Object moved $70 (there would be half spools on the bearings, and end caps), say 20 for discussion, here = $1400
disks @ $960 axels @ $420 spools @ 1400 = $2780 and that is not bearings and frame,
yes you may find cheaper or lower cost parts, but just the disks will bring on close to the price of a good used, is my guess,
Did not realize all the parts added up to that much since I cannot find any catalog around since I cleaned out my pile of catalogs.Getting my 50+ yr old Ford model "J" ones apart to replace discs will be determining factor on what I do.
   / Anybody build a set of 3 pt discs ? #7
I just bought a disc and in the process of doing that, I priced building one myself because I have all the fabrication tools and do enough volume with my steel mill to have pretty good pricing. After I priced all the materials to build equivalent to what I bought, I came out saving $100. On a $1700 (pre-tax) disc. It would've taken at least 8 - 10 hours so that wasn't worth it to me.
The implement manufacturers must be getting a screaming good deal on disc blades, bearings and shafts or they're living on a very low margin.
YMMV, that was just my experience.
2013 Ford F-250 XL (A50120)
2013 Ford F-250 XL...
2022 JOHN DEERE 26G EXCAVATOR (A51242)
2022 JOHN DEERE...
2011 PETERBILT 337 (A52472)
2011 PETERBILT 337...
2016 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51242)
2016 CATERPILLAR...
2015 Ford Expedition EL XLT SUV (A50324)
2015 Ford...
2014 CATERPILLAR 259D SKID STEER (A51242)
2014 CATERPILLAR...
