Streetcar
Veteran Member
Another reason for no conduit above ground, most conduit is not rated for UV continuous exposure. The span between supports can get brittle and break
Per the plant electrician at work gray PVC conduit is rated for continuous UV exposure but it has to be supported it at least every four feet, if you doing that you may as well just bury it because it'll be a pain trying to get that through the woods.Another reason for no conduit above ground, most conduit is not rated for UV continuous exposure. The span between supports can get brittle and break
When I put in the #8 wire for my camper, the run under ground was only about 100 feet but I knew I wouldn't be able to pull the stiff cable thru the conduit so I dug the trench, the slid each PVC section of pipe over the cable individually to then glue it to the mating one. It took a little time to slide each section of pipe over the entire wire run but when the 90 ell at the end came up, I only had a short section to go and the 90 was easy to run the cable thru for the 4 feet of cable that I had left to go.
I think this approach for your conduit might work also and no need for cable lube especially if you use 10 foot joints of conduit.
