ledebuhr1:
First off, thank you RaT for the referral. Anyway, I have a 5030HSTC which is the largest of the series.
Having 4 previous Kubota's with no cabs and being an old fart, I decided the next utility tractor was going to have a cab, just like our Ag tractors.
I am mostly happy with Kubotas cab on the L series with a few exceptions. The stock configured air conditioning sucks. There is too much glass area and the tint isn't deep enough to reduce the reflected heat to the point where the ac unit can keep the cab comfortable in hot weather. I modified the ac unit and now it does a good job. There is a thread posted about my fix, maybe RaT knows how to link it, I don't. Kubota is also aware of the problem and they are also aware of my solution (R&D in California). The side wing windows will not stay open during rough going and the front windshield wiper doesn't clear enough of the glass for comfortable viewing in the rain.
On the plus side, the cab is quiet, more so than JD (I have one of those). The fit and finish and ergo's are excellent. Above head level controls are also excellent. The heater is excellent. The sound system is good, not as good as a car, but this isn't a car either.
The view from the cab with the FEL attached is also very good. The only time the loader isn't in view is when the loader is at full vertical reach.
The view to the rear, especially when hooking to the draw bar is excellent, however, the seat needs to swivel to the side about 30 degrees. The seat also need to be tilted back about 10 degrees. You have a tendency to slide forward if your seat belt isn't fastened.
Ingress and egress is excellent. The all glass doors are wide and swing completely out of the way. You have to make a conscious effort to shut the doors as the cab is almost air tight.
I opted for the extra work lights, front and rear. The stock headlights are weak, the auxiliary lights are a must.
I have used mine all summer in a haying operation on some pretty rough ground and I have yet to hear a squeak or rattle. Overall, the cab L series is well designed and is an excellent first time effort for Kubota.
