Anyone built a seed drill?
   / Anyone built a seed drill? #11
I have alreadywritten this once and lost the signal immediately I hit the "post" key. Sod's Law they say. So here goes again....
Jethroe did not invent the seed drill, he merely improved on it, and added a lot of gears, pulleys chains, etc., very similar to many drills now in use.
Building a drill is quite straightforward. I too did many Google searches and found virtually nothing. I also post questions to all the forums I know (including this one for a thresher which I really, really need). If you want a drop type then look at the Limestone Spreader construction details from the Ag Experimental Station, Uni of Illinois (no site address because I printed a copy and did not save the info) and modify spacings. The agitator arm can be activated from the rear tractor tyre tread.
I am currently building a 2 row corn drill (50cms double row and 1 metre between double rows) using a scarifier as the basic frame with spider wheels attached to a pipe that fits over a smaller carrying pipe and is bolted to allow removal of the wheels for use on other planned drills for beans, and grass/sorghum/oats. The carrying pipe has a poly pipe fitted over it, again bolted through, and hard poly joining flanges glued to the poly as seed plates (already with cut outs for picking up seeds). This poly has a yet bigger poly used as bushes (short sections) and fixed to the scarifier frame with strips of old galvanised iron roofing sheets - I am using scrap as far as possible. just for the feel good factor. The seed boxes are plastic and cut out to fit the flanges (a frame is needed to support the seed boxes in position). The seed plates deliver into large funnels fitted into pipe welded to the back of the selected scarifier tines. I need to be sowing by the end of the month so it is virtually prepared with only some welding to be done. I have not yet decided on press wheels, probably not necessary as the land is quite heavy. All being well, the 3 metres run of one turn of the spider wheels should be delivering seed at about 17cms (7") spacings in the row for hopefully about 80,000 seeds to the hectare. I do not own a camera so no photos. Old McDonald.
   / Anyone built a seed drill? #12
</font><font color="blue" class="small">( "BUT..did you know that Jetho Tull invented the seed drill??"
That just goes to show my ignorance. I thought he was too young to have been born early enough to have invented it in the 1930's. )</font>
Jethro Tull 1674-1741
Short Jethro Tull Bio
I'd say he was a bit on the old side myself /forums/images/graemlins/grin.gif
   / Anyone built a seed drill? #13
I opened this one up all excited and get nothing? I had great hopes of finding someone else had already done it once!
   / Anyone built a seed drill? #14
Me Too! I've the same idea, but broke as they come. someone on this site was gonna do the same a couple yrs back. I think he was gonna use some gandy drop spreader boxes to start with. keep us informed of your progress. bjr
   / Anyone built a seed drill? #15
Somebody needs to sell an inexpensive 1 or 2 row planter. With all of the hobby farmers and food plot fans out there, there has to be a huge market for them. Nearly all of us guys that can't resist nifty accessories for our toys...uh, I mean tractors...would figure out a reason why we needed one.:cool:
   / Anyone built a seed drill? #16
I am in the process of building a seeder for use on planting new lawns as well as overseeding existing lawns that are in poor shape.
the machine will consist of a 6' pulverizor which I made this past summer, and for the seed I am using a small grass seed box off the front of a international grain drill. it will be driven off of the roller on the pulverizor, which will also pack the seed into the ground . I will also have to mount some kind of adjustiable gauge wheels on the front of the rig to control how deep the shanks on the front of it are in the ground because you don't want to burry the seed to deep ( 1/4" to 1/2" max).
Hopefully if I can get some free time here soon I will get back to working on it and take some pictures for you all, but with all the snow we have been getting lattely its hard to think about spring seeding.
Thanks, Barret.
   / Anyone built a seed drill? #17
You could make one, buy two of these and mount them to a bar that fixes to your 3 pt hitch :D
Toxic- I'm looking foreward to pictures :) I'm want to build one that will punch seeds down an inch or two for forage/hay fields, but I gotta prep the fields first! Anyone want to build a stone house?
   / Anyone built a seed drill? #18
Poke here
   / Anyone built a seed drill? #19
| Edit button not working :rolleyes:
   / Anyone built a seed drill? #20
You need to obtain an old Garber or Sears or Gravely 4' or 5' drop seeder. You can chain drive it from your cultipacker, or just mount it so that the wheels roll on top of one of the cultipacker rolls. I've done it many times before, currently working on putting a seeder on a new Aerway aerator, this one is going to be a little trickier, as its hydraulic driven!:cool:
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A55745)
2012 BRUMLEY...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
2013 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP TRAILER (A58214)
2013 TRAVIS BODY &...
2003 Big Tex 10PI...
BUNDLE OF 4" - 6" X 12' BUILDING PURLIN (A54757)
BUNDLE OF 4" - 6"...
