Anyone debate buying vs renting a pressure washer?
   / Anyone debate buying vs renting a pressure washer? #21
Craftsman 2600, around 10 years old & some dummy didn't drain the pump, ruined an outlet pipe($10) & a wand, not bad & the dummy remembers to drain it now during the winter.
dummy, er, Ronnie
   / Anyone debate buying vs renting a pressure washer? #22
Hard to resist this one...
I used to own a $5,000.00 hot water (diesel fired) pressure washer with a Cat pump (the best) and a Honda 13 horse electric start engine but I (smartly) traded it away on a rebuild of my gooseneck trailer. It was a nice machine and I used the heck out of it, but as it aged, it became a PITA to keep running proplerly...and it was a heavy monster. 4000 psi @4gpm @180 degree water temp really cuts grease on farm equipment and also peels paint pretty well. I could use it to cut wooden planks too, ragged cut, but cut none the less... It's gone and my goose has flip ramps on the beavertail, all LED lights, new brakes, sandblast and paint and I don't have the beast in the shop anymore.
Here's my solution....
I bought a Harbor Freight 2500 PSI gas washer with a Pred motor. It's a cold washer so grease can be an issue but Purple Power on grease works pretty well. Ir won't peel paint (well, it would with a '0' degree tip I guess, but I always use a fan tip anyway. The Pred starts with 2 pulls. The pump isn't a CAT but it's not bad and I picked up a second pump from Northern Hydraulics it's an AR btw, when this one pukes and it will because the engines always outlast the pumps.
I got is on sale (with a coupon) for 265 bucks. It works dandy, I clean my big AG tractors, my pickup, the wife's car, the decks, the houses...you name it. I use the heck out of it.
The trick, if you will, to keep a pressure washer working properly (besides changing the oil in the engine and ocassionally a new sparkplug), is... Change the oil in the pressure washer pump too. Use 30 weight non detergent motor oil and change the pump oil when you change the motor oil. Secondly, if you run well water in your washer, flush the pump out with bottled water when you are done with it. Well water, left in the pump is death from mineral deposits. Third, keep the unit warm in the winter and/or fill with RV antifreeze. Finally, don't run it dry. Those pistons inside don't like to be run dry....
For basically 250 bucks, the HF pressure washer is a dang good buy. I'm happy with mine. The only downside is the cheap supply hose, it's plastic and if you kink it, it's done. I am careful about making sure it's never kinked.... you can buy a real hose replacement but so far (2 years), mine is fine. Hard to beat a Pred engine and hard to beat a 250 buck pressure washer on a nice powder coat wheeled frame and an assortment of 5 tips and a low pressure soap injector.
2500 PSI @ 2.5 GPM cold aint too shabby (I put a liquid filled gage on mine) and it puts out about 2200 psi, thats plenty. HF always inflates their specs anyway.
   / Anyone debate buying vs renting a pressure washer? #23
A have a relatively cheap pressure washer with a Honda motor. The cheap pump lasted about a year before it crapped out. I put a Cat pump on it which cost nearly as much as the whole pressure washer. Then I bought another pressure washer with the better Honda GX motor at an auction for $60.
   / Anyone debate buying vs renting a pressure washer? #24
I have 3 electrics: a Stihl bought new, a red one from a garage sale new in a box for $10, and a John Deere also from a garage sale (free). The Stihl is my main unit. Had it over 20 years. I wash the spider webs off the barn walls and ceilings without soaking the building. I even use it to spray trees: pto generator off the back, 150 gal horse water trough with bug spray in the bucket up front. Works like a charm. The Red one is a popular brand but its out in the barn now so I can't tell you the make. When I had horses, they loved a low pressure misting with water from a distance. Soaps and cleaners are all over the place at estate sales. I even got a garage floor concrete washing swirl wand that I have not tried yet at a local sale. I think people buy them, buy extra soaps/cleaners, wash their deck a few times with one, then die. Hmmm....
The Deere may need some work, discontinued model, save for repair on a rainy day.
   / Anyone debate buying vs renting a pressure washer? #25
My rule of thumb is 2 pumps to one engine so I always buy a spare pump. My opinion of Honda motors is checkered. I had a Honda GC on my tiller and it was basically junk so the tiller got a Pred instead. The Lifan (predator) motors that HF sells are all bargains, price versus value. I'm about to buy a big V twin to replace a Kohler that developed a rod knock.
   / Anyone debate buying vs renting a pressure washer? #26
The GC is their cheapest series motor. I have never had any trouble with mine, and I have 5. The Honda motor on the generator I bough fired right up after sitting with gas in it for 2 years.
   / Anyone debate buying vs renting a pressure washer? #27
Maybe I got a bad one. I don't know. It never ran right, always loped. I took it off and Craigslisted it and offed it and the money I got for it, paid for the Pred and I had change left too.
I had the red Honda 13 horse on my diesel fired pressure washer and it was flawless so I was disapointed with the tiller motor. Why build a cheap motor that compromises your reputation... I don't get that at all.
I have 3 Preds on 3 different things now. The one on my Cub Cadet tiller, the one on my pressure washer and one on my little Troy-Bilt Pony tiller, I use the cultivate between my hills of potatoes. That had a Tecumseh that burned more oil than gas. never worried about skeeters tilling potatoes, the Tecumseh kept the skeeters away....lol
   / Anyone debate buying vs renting a pressure washer? #28
I haven't ever understood that logic either, but it seems almost every manufacturer does it.
If I buy one, what do you think of the one Sam's Club has here?
It's a 4000 PSI Simpson model PS4033 for $799. Two year warranty.
Honda GX270 engine, industrial triplex pump.
Any thoughts on that one?
   / Anyone debate buying vs renting a pressure washer? #30
To cut to the chase - good motor, decent pump, from what you describe as your uses it should last a LONG time with proper care.
2013 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2013 Ford F-250...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
Heavy Duty Hydraulic 84" Broom  (A52384)
Heavy Duty...
Year-A-Round 550 Gravity Wagon (A50774)
Year-A-Round 550...
Wood Fence Posts (A50121)
Wood Fence Posts...
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
