Anyone experienced in Vinyl Fence Washing??
   / Anyone experienced in Vinyl Fence Washing??
This is exactley how I do it and it works great!
Had I known vinal fencing would the green mold / mildew on it I would never put it up
Well ... I don't know about that. Just look at some of the pipe fence around here. I'll put up with the green mold, mildew and etc ... rather pressure wash a fence than paint a rusted pipe fence.
   / Anyone experienced in Vinyl Fence Washing?? #12
I helped wash a neighbors fence in the pouring rain... hey, it worked.
   / Anyone experienced in Vinyl Fence Washing?? #13
I used some stuff called Jomax (walmart/lowes/home depot) that did a good job cleaning vinyl siding.. It is a detergent that you mix with bleach.. Spray it on (using pump sprayer).. let it soak in and the mold/mildew etc starts to run off.. Rinse with water and your done.. May take a couple times if really dirty..
Brian
This is exactly what I use and how I use it. I use it on my vinyl fence, but I also use it to wash clients homes. I would never, EVER, use a pressure washer on a house. Instead, I use a pump sprayer with Jomax in it and spray down the house. I then come back and rinse it off. The results are always very impressive.
Jomax is made by Zinser, who makes the best primer available. It's good stuff!!!!
Eddie
   / Anyone experienced in Vinyl Fence Washing?? #14
Eddie
just a few words of advice for anyone using Jomax or any other bleach mixture.. DO NOT spray above your head without wearing a mask of some sort..
I was on a ladder spraying directly above my head (trying to reach the second story using a 6' ladder) and the overspray was falling back down on me.. I ended up with chemical burns in my nose from the bleach - but a copay at the dr and a steriod nasal spray cleared it right up.. LOL
Brian
   / Anyone experienced in Vinyl Fence Washing?? #15
I use a gas powered pressurewaser to clean house,concret and fence. I use a solution of 5 gals water, 1gal bleach, and 2cups of liquid laundry detergent. Put the solution in a pumpup sprayer and spray work area from top to bottom, let set for couple of minutes and then power wash. Usually a garden hose wil take grime off after the solution has been sprayed on.
Sounds like that solution will clean anything ...
   / Anyone experienced in Vinyl Fence Washing?? #17
I use this product on my house and anywhere mildew and grime grows. I mix it 4:1. Spray on, let it sit for 15 mins and spray off. Spray it off with as little pressure and a garden hose. Of course, use of a pressure washer makes quick work. I got the product at a local home improvement store. Well worth the money.
   / Anyone experienced in Vinyl Fence Washing?? #18
I have always had great success cleaning vinyl siding and vinyl products with the following method: I mis one part water with one part clorox (or dollar store bleach), one cup of Spic n' Span concentrate, and about 3 ounces of Dawn. All mixed up in a cheap hand sprayer and sprayed onto the already wet down surface. Let sit for a few minues.
Dwepending on how bad the mold/mildew is, I usually spray down with clear water after the application; if real bad, I will scrub down the wall using a "siding brush" on a telescoping pole, only light action is needed.
Rinse down thoroughly, viola, looks like a new wall/new house. One other thing, when applying the cleaning solution, I always start at the bottome and go up. That eliminates streaking as that solution is pretty strong.
P.S.--that comment about Zinser, yes I agree 100+%, it is the best primer on the retail market. Great product!
2018 KUBOTA SVL95-2S SKID STEER (A51242)
2018 KUBOTA...
2013 John Deere 544K Articulated Wheel Loader (A50322)
2013 John Deere...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51572)
IMPORTANT PLEASE...
2019 Kubota F3990 72 in. Commercial Mower (A50324)
2019 Kubota F3990...
2016 FREIGHTLINER 2500 SPRINTER VAN (A51222)
2016 FREIGHTLINER...
Memo 98 Loader with Brackets (A50514)
Memo 98 Loader...
