Anyone Familiar with Husqvarna 345R used as Brush Cutter ???
   / Anyone Familiar with Husqvarna 345R used as Brush Cutter ??? #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
I have a lot of finger diameter glossy buckthorn I want to cut and saw a used 345R . I am wondering what people have to say about it. Thank you. I can never beat the stuff but hold it in check by cutting. I am getting tired of the hand loppers and wonder about a brush saw.
gg
   / Anyone Familiar with Husqvarna 345R used as Brush Cutter ??? #2
I have a 345FR, and it's an absolute beast. Primary use for me was clearing heavy pond vegetation 3-6' high. I have never used the saw blade that came with it because I wasn't using it on woody stuff. I use the grass blade extensively. No problems whatsoever. It is heavy and loud. My only complaint is that I wish the shaft was a bit longer.
Thanks. I already bought it - I figured it wouldn't last long. So far I agree with your beast assessment. Way better than hands and knees with loppers or chainsaw.
gg
   / Anyone Familiar with Husqvarna 345R used as Brush Cutter ??? #4
For cutting stuff at ground level consider getting one of the push trimmers.
I have one of the old Craftsman trimmers with a Briggs engine and it is the best tool in my arsenal for heavy brush. I also adapted a 10" saw blade for cutting small trees but I rarely need or use it.
Thanks for the suggestion but if what you are talking about is like a DR Trimmer it wouldn't work for me very well. The biggest area I cut used to be an 8 acre beaver pond before the dam went out. It is covered with rotting logs and broken or chewed off stumps all hidden in the brush. I can hardly walk thru it never mind push something. I only want to cut the invasive buckthorn. Any other vegetation I am fine with and want to leave as much as I can hoping it will take over which it slowly is. Property lines and power lines are other rough areas I do.
gg
(4) Skid Steer Tires (A46502)
(4) Skid Steer...
Komatsu D51PXi Crawler Tractor Dozer (A44571)
Komatsu D51PXi...
Ingersoll Rand 2545 120 Gallon Air Compressor (A46683)
Ingersoll Rand...
2025 Unused International MV607 TMA Attenuator Truck (A45336)
2025 Unused...
Adams 5-Ton Ground-Driven Fertilizer Spreader  Reliable & Field-Ready (A48561)
Adams 5-Ton...
Set of (2) Rolls of Woven Wire (A46502)
Set of (2) Rolls...
