anyone got an idea about this?
   / anyone got an idea about this? #21
While I didn't check the math, just remember that you generally don't fill the tire to capacity with fluid. Rather you generally fill to just above the axle - allowing for some amount of air to remain in the tire.
Mike
Down here in Fl. everyone I know fills tires full....
   / anyone got an idea about this? #22
The way mine was filled was with the valve stem at about 11 o'clock. That leaves just a little air in the tire to make it ride better.
   / anyone got an idea about this? #23
Rolling--I'm running the 14.9's as I wanted more than the standard tire but I wasn't sure about the 16.9's. My 5103 is a 2wd also because I figured with pretty much level ground and that I really don't expect to be using ground engaging jobs on a regular basis.
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A52748)
Kuhns AE10 Small...
(8) 2 PLUG VALVES (A52472)
(8) 2 PLUG VALVES...
Guard Rail Joints (A51692)
Guard Rail Joints...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
