Anyone have experiences with Timber Block homes?
   / Anyone have experiences with Timber Block homes? #1
MGH PA
Northcentral, PA
2005 Gravely 148Z 48" ZTR
My wife an I are in the very early stages of planning our future home build and are just exploring some options. I've been saving plans, images, etc., for a few years to help better plan. Now that we're about 1-2 years out from building, we're starting to examine builders in our area. We're setting up appointments in the coming weeks to begin interviewing.
This leads me to my question. A local builder here deals with Timber Block homes (Timber Block | Engineered Log Homes). At first, I was really against such a system, but I'm starting to look into this a little more after reading about it online in a few other publications.
Do any of you have experiences with this system? Would love to hear everyone's thoughts (both good and bad).
   / Anyone have experiences with Timber Block homes? #2
Your gut is right- I’d stay away IMHO. A fake log look on a SIPS doesn’t sound good at all. SIPS are a PTIA Plus, the log home is a never ending maintenance hassle- beyond about any other construction method. SIPS and log homes have been around for years- if they worked everyone would be doing it. This timber block is just the latest rebranding of a failed residential construction method.
Btw- SIPS does have its place in a commercial environment.
   / Anyone have experiences with Timber Block homes? #3
Standard stick frame built homes are the most common type of home construction for a very good reason. It's the most economical. It's also the most flexible. You can make it as fancy as you want, or as simple as you want.
Any time you go with a different method, you have to deal with issues that nobody else has to deal with. Usually more maintenance once it's done and more expense to build it.
   / Anyone have experiences with Timber Block homes? #4
I agree with both above. If you want a well insulated home (sips primary advantage) spend your money on spray foam & high performance windows & doors in/on a conventionally framed house. That will keep you with all locally based subs throughout the whole process. Sip's require a well trained (expensive & specialized) crew for panel erection. There are some EXTREMELY important construction details necessary to protect the panels, I won't go into that but it's moisture related (de-lamination & rotting of the panels) . Then there is all your trade's, the plumber, electrician & hvac are the highly effected but it go's all the way down the line with maybe the foundation, flooring & painting guy's (price) being unaffected.
   / Anyone have experiences with Timber Block homes? #5
I don't know this particular system, but i did SIPs for my walls. They are great, IMO. Was it probably a bit more expensive than stick framing? Not sure as i never quoted stick. Any SIPs company will know firms that do erection, so that is not a big deal. They go up super fast. The only real downside is wiring is more of a PITA, but there are strategies to minimize the pain. It doesn't really affect any other trades, so not sure where you get that from. Nobody puts plumbing in an exterior wall in any northern climate, except perhaps an occasional vent line, but there are typically ways around that easily enough. Same with HVAC. Most all utilities other than electric are run in interior walls and floors only. The added bonus is easy to hang whatever you want anywhere as the continuous OSB is behind all the drywall. Drive a screw anywhere you want. Very airtight and well insulated in one step. Now i did not do SIPs roof as that became significantly too complicated with my roof design, so it was just trusses with raised energy heels. Then a thin coat of foam to seal everything, and blown-in on top. No comments on the log aspect of it as i have no experience with it.
   / Anyone have experiences with Timber Block homes? #6
My current home is a log home, and my wife and I will probably never live in a stick built home again. I have no experience with Timber Block other than seeing their ads in Log Home Living, but R30 walls and R40 roof is nothing to complain at. I do like the look of their hand peeled log exterior. Most of your neighbors in PA in stick built probably have R19-21 2x6 wall construction. I would not dismiss them because they don't use common construction, but I would visit their models, and if you can, talk with other owners.
Sort of my thoughts. Everyone here does run of the mill block wall basements (with no exterior insulation), 2x6 walls/r21 fiberglass, OSB everything (more builders are using the ZIP variety at least now), and cheap vinyl siding. I don稚 want run of the mill, and I want energy efficiency.
We were considering a timber frame (still haven稚 written it off) and Woodhouse is only an hour from here and they own Murus panels (they make SIPS). Was very impressed with the technology, but you would definitely need a crew who knows what theyæ±*e doing.
Thanks for the insight, though, everyone. I will be interviewing quite a few builders in the future to see what experience they have with energy efficiency construction. This was just one option and I saw that a local builder was a rep/installer for them as well.
   / Anyone have experiences with Timber Block homes? #8
We were considering a timber frame (still haven稚 written it off) and Woodhouse is only an hour from here and they own Murus panels (they make SIPS). Was very impressed with the technology, but you would definitely need a crew who knows what they?*e doing.
We built a timberframe home 4 years ago but didn't use sips. I wanted piece of mind that if the roof ever leaked or if we had siding issues it could be easily fixed.
We closed in the home with traditional framing using 2x4 walls, 2x6 roof, and insulated the cavities completely with closed cell spray foam. 2x4 walls because anything more than 3-1/2" of closed cell foam seemed to be a waist in the walls. There just wasn't an added benefit vs cost to increase the wall and foam thickness.
For the basement no exterior insulation, just sprayed 2" of closed cell on the interior walls.
I'm not sure we saved a ton of money this way due to the cost of closed cell insulation however we ended up with a home that is extremely energy efficient for its size and complexity and don't have to worry about the long term reliability of sips. Total of 3600 sq/ft+- on the first two floors plus finished basement. Our ACH50 when blower door tested was 1.9. The house is very open with 26' living room ceiling and our fireplace in the living room will heat all but the furthest bedroom down to about 20 degrees outside. We have been extremely pleased with the envelope performance. In fact the only issue we had was our HVAC guy really missed the mark and way oversized our HVAC needs.
Jeremy
   / Anyone have experiences with Timber Block homes? #9
When talking energy efficiancy, you have to be careful of what you are hearing. It is very common to twist ratings around to make something seem better then something else. In a house, there are two different things happening when talking insulation and energy efficiency. The first, and easiest is that heat rises, so insulating the attic is the easiest to understand. Foam is the best because it also seals off air. If you can afford it, and if you will be in the house long enough to see the return on your investment, it's a great product. It's also very good if you have vaulted ceilings or a thin distance between your exterior roof and interior ceiling. For a lot less money, I like blown in insulation in an attic. The latest standard is R60, which is about 2 feet thick. It should look like fresh snow when done, and it should never be disturbed. This is also why I never like putting the AC system in the attic, and never store anything up there. Attic space should only be used for insulation in my opinion.
I'm also very much against skylights. While there may have been an argument at one time that it's cheaper to have a skylight to light up a room during the day then to turn on a light bulb, that argument doesn't work anymore with LED lights. There is never a good reason to have a skylight. It's just a massive hole in your ceiling that has almost no R value. And while people selling skylights like to tell you they have solved all the leaking problems, or it leaked because it was installed wrong, I believe that they will all leak sooner or later. Just say no to skylights.
Wall insulation is where things get really confusing. It's actually very simple, but people selling products have muddied it up so much that it's easy to over think and confuse what's happening with the exterior walls. First, the force that you are fighting with the walls is wind. Wind gets through your walls and defeats the insulation that you have there. The number one goal of an exterior wall is to keep the wind out. Bricks allow a massive amount of wind through them. House wrap is pretty good at stopping the wind, but it needs to be taped and sealed up everywhere. Zip siding is better then house wrap, but it's quite a bit more expensive then standard OSB and house wrap. My house has Zip siding and when I build my addition, it will have Zip siding. I feel that expense is worth it.
From what I'm reading in the trade magazines that I get, rubberized paint type products are probably going to be the future in home building. They are using it more and more around windows instead of tape. I'm also reading that they are rolling it on the entire exterior of the the OSB or plywood, covering every inch to achieve the highest level of efficiency. There have been all sorts of studies done on double framed walls with foam between the studs to stop therm jumping, and then building with SIPS to get an even higher R value, but none of those very expensive methods actually achieve anything above a certain point that you already get when super sealing the exterior walls with something like Zip system or rubberized paints. Another huge consideration is that every double pained window has an R value of 3 or less. What good is making your wall R30 when you have a big opening that is only R2.5? You can get three pane, and I know one guy who lived close to a major airport that got 4 pane glass. The price is crazy, but you do notice a difference in sound. He didn't see any change in his energy bill after those windows where installed, but the rest of the house was well insulated, and he really didn't have any issues with his 2 pane windows before going to 4 pane. It was all for sound.
In all reality, you will never notice any difference in your wall insulation going above R19 if your walls are air tight and able to keep out the wind. If the wind can get through your walls, it wont matter what you use on your walls, they will not insulate.
Solid logs are not great at insulating for walls. But that's not that big of a deal if they are able to keep the wind out. Your chinking, or sealing off the air is all that matters. Log companies claim that the thickness of their logs is what does the job, but that's just a sales gimmick. Keeping the wind out is all that matters.
Going with alternative building methods is for those who want something special and unique. Not for somebody wanting to build an energy efficient home with limited funds.
I had a friend back in CA who was into riding mountain bikes. He was fifty pounds overweight and not what anybody would consider an athlete. But he really liked riding and he didn't think he was overweight at all. So to make up for not being able to keep up with his friends, he spent a fortune on things to make his big better and lighter. His seat cost him $600 and it was several ounces lighter then anybody else's. He spent more, felt better about it, but that didn't make him any better and keeping up with is friends. Houses are the same way. You can spend a lot more on products that sound good, may be the latest "thing" and you see on TV, but they don't actually make any real world improvement to your home.
When planning your home, focus on the floor plan, storage, usable square footage, curb appeal and resale value. Read up on what's available to make it something you will enjoy living in, and last the longest with the least amount of work. You mentioned vinyl siding, what about going with Hardie siding instead? Rock is becoming more and more affordable. Exposed beams, cedar posts, and trim add a lot to the look of a home without adding a lot of expense. Forget the alternative building methods, they will just lead you down a hole that is impossible to get out of.
   / Anyone have experiences with Timber Block homes? #10
If the energy efficiency is what you are after I’d check out the building science website. They are an Independant outfit so you won’t get the salesman spin.
With some exterior rigid foam and blown cellulose your new home will be right up there with the best of the best.
Read up on SIPS. It’s not all good- rot etc are issues. My wife specs SIPS all the time- just not in the residential setting. I’ve built a SIPS house and wouldn’t do it again. When you are the one cutting channels, dropping hot steel balls etc you realize the theory and reality are very different. Plus walls (including the windows) only account for about 30% of your heat loss/gain.
Anyway- you can get lost researching- check out the articles at the building science website. Soon you will more concerned with the permeability of the building paper and the roof/attic venting.
2010 Ford Fusion SE Sedan (A44572)
2010 Ford Fusion...
2022 Ram 2500 Pickup Truck, VIN # 3C6UR5HL9NG130419 (A44391)
2022 Ram 2500...
2015 Ford Fiesta Sedan (A44572)
2015 Ford Fiesta...
2015 Ford F-550 Crew Cab Godwin 184U Mason Dump Truck (A44571)
2015 Ford F-550...
Exide SCR200 36V Industrial Forklift Battery Charger (A44571)
Exide SCR200 36V...
2015 Massey Ferguson GC1720 Tractor (A44391)
2015 Massey...
