Anyone know how to add a spool gun to a Lincoln Wire Matic 255?
   / Anyone know how to add a spool gun to a Lincoln Wire Matic 255? #1
Tags
Platinum Member
Connecticut
BX2360/ Kubota SVL90-2/ Kobelco 115SR/ Takeuchi TB260
Ok, this just maybe stubborn on my part but I'll ask anyway....I own a Lincoln Wire Matic 255, I stupidly purchased it years ago WITHOUT the spool gun control kit. The spool gun control kit is no longer available from Lincoln, I have been looking for a used 255 with the kit with 0 luck. I don't use it a ton, I mostly use it during the winter months when I'm not busy with my excavation business to weld up buckets and some odd jobs here and there, so it doesn't have a lot of heavy use. I really don't want to buy a new Mig welder with all the electronics since mine works just fine. That being said, does anyone know if it's possible to add a spool gun to this welder any other way?? Any help would be greatly appreciated!
   / Anyone know how to add a spool gun to a Lincoln Wire Matic 255? #3
   / Anyone know how to add a spool gun to a Lincoln Wire Matic 255? #4
You may need an adapter for your amphenol pin out but I THINK a Miller WC24 controller and 30A spool gun will work on any CV machine, if Lincoln can't supply you with OEM.
   / Anyone know how to add a spool gun to a Lincoln Wire Matic 255? #5
I had a Wirematic 255 back in the day. It had the module that went on the bottom of the front panel. You weren't dumb to buy it without the panel. That panel was $450.00 and the Lincoln spoolgun was $695.00. The welder was $1100.00. The Wirematic 255 is a fine welder for what it is and has a great Arc. Now days you can buy an import spoolgun for $300.00 and hook it to your welder without the module. You wont have quite the control you would have with the OEM module set up but you can do aluminum with the spoolgun. Or, The 255 is still worth what it was new and you could probably swap for something that already has a spool gun without spending much and it might even be a Mig Tig Stick unit. Options options options.
Thanks for all the help so far....the original control kit is no longer available from Lincoln, I've checked with them and even some of the local welder repair shops with no luck.
I am also not an electrical wizard or even a wizards apprentice, so I would be up for trying anything if someone can point me in the general direction when it comes to wiring something up.
The simplest so far seems like the setup from USA weld, I'm gonna give them a call and see what they say.
Ive looked into the USA weld setup and after doing some research it really seems that people are not really happy with that setup...
Is there any other way to get a spool hooked up to this unit or should I just give in and start saving for a new mig welder??
   / Anyone know how to add a spool gun to a Lincoln Wire Matic 255? #8
I bought a couple of 255s last fall and was going to sell one to friends company to use with an existing Lincoln gun they had. We "assumed" being the same make, it would work. As it turned out, the guns are machine specific and I lost the sale.
Just for starters, the connectors were different, and I could have changed that, but Lincoln told me, it still would not work.
The parts are available for a POWER MIG 255, just not for the older less-full-of-electronics WIRE MATIC 255....lucky me...if anyone comes across one that's in parts (or not) but has the original control kit on the bottom front panel I would be very interested in buying it. I've had an ad on Craigslist now for a couple of months looking for one but it hasn't garnered any attention yet....
   / Anyone know how to add a spool gun to a Lincoln Wire Matic 255? #10
I know a lot of repair facilities in multiple states. I'll make a few calls and see what's out there. I'm surprised this item is so hard to find. It was a popular welder and spool guns were coming into their own at that time. Lincoln didn't make that spool gun but they sourced it in the USA. I'll check with that company to see if they offer anything as well. The spoolgun module for this machine was complicated with pre flow / post flow timers on the board.
1827 (A51248)
1827 (A51248)
2003 POLAR TANK CRUDE TRAILER (A55745)
2003 POLAR TANK...
2024 AGT LRT23 Mini Stand-on Track Loader Skid Steer (A53421)
2024 AGT LRT23...
2010 GLOBAL TRI AXLE HAUL TRAILER (A55745)
2010 GLOBAL TRI...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
