Anyone know how to match bottom plow to tractor?
   / Anyone know how to match bottom plow to tractor? #1
carolinadozer
raleigh, nc
John deere 2440
I have A JD 2440 (62hp, I think). I'm thinking a 3-bottom plow is all the tractor can handle, but have access to a free 4-bottom plow. Can anyone give advice. Thanks a ton.
   / Anyone know how to match bottom plow to tractor? #2
I would think it would handle 4-14's ok. I was told for every 3 feet of disk you can pull you can pull one bottom of plow. I pull a 10 foot disk so I am looking at a 3-14 plow behind a 40 horse tractor. Some of the old Farmall M's would pull 4 bottom around here but 3 was better. Your tractor has more power then an M ever had. If you can get it for free I would just try it and if it is to big buy a 3 bottom but I believe you should pull it with no problem. A good speed for plowing is 4 to 5 mph.
   / Anyone know how to match bottom plow to tractor? #3
Take the 4-bottom. If your tractor can't pull it, remove the last bottom.
   / Anyone know how to match bottom plow to tractor? #4
I've got a 2440. Owned it since new in '79. It's done a little plowing in it's day. In all but the easiest of conditions, it'll have all the plow it needs with 3-16"'s. 3X14"'s would be an easy load. 4X14" is out of the question in my ground, and it's what I'd consider reasonably easy plowing.
Thanks for all the info.
TBN is bar none, the best information site w/ the most informed members I have found.
The idea of removing one to make a three never crossed my mind. DUH!
Thanks again
   / Anyone know how to match bottom plow to tractor? #6
I agree with FWJ we had a 3020 Diesel (65 hp) and a 4 bottom JD plow and it was all it wanted. Plus on the tricycle front it would get very light when the plow was picked up. I have had the front end high enough to clear a 4 foot high fence. Not a good feeling
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2012 VOLVO VNL TANDEM AXLE SLEEPER (A52576)
2012 VOLVO VNL...
2018 Wacker Neuson WL 38 (A53472)
2018 Wacker Neuson...
2007 WABASH 53FT DRY VAN TRAILER (A52576)
2007 WABASH 53FT...
