Anyone know how to wire a drill motor?
   / Anyone know how to wire a drill motor? #1
Travelover
Elite Member
Washington
B7100
Maybe this is slightly off topic to tractors, but we have some pretty bright folks here..
I was given a bunch of old tools including a Milwaukee 3/8" 110v drill. It didn't work and when I disassembled it, I found that the reversing switch had crumbled. The trigger variable speed switch is OK. I checked on line and found the switch assembly is about $40! My thought is that I can replace the reversing switch function with a DPDT switch.
Anyone know how the two brushes and two field leads are supposed to be wired - i.e. are the brushes and field coils wired in series or parallel? Is the drill rotation reversed by swapping polarity between the brushes and the field?
Thanks in advance!
OK, I'll answer my own post to help anyone else that might search this subject in the future.
I figured this out by trial and error by powering the drill from a 24 volt AC transformer temporarily, to minimize the "collateral damage".
The brushes and the field are wired in series. The drill is reversed by a DPDT (double pole double throw switch) which reverses the polarity of the field relative to the brushes (armature). New DPDT switch at Radio Shack - 2 for $2.99.
Satisfaction of fixing it myself, priceless.
   / Anyone know how to wire a drill motor? #3
Good for you. nothing like figuring it out yourself sure gives one a sence of accomplishment.
   / Anyone know how to wire a drill motor? #4
Glad you got it fixed.
If it would'nt have been a Milwaukee,i'd say chuck it.But since it is a Milwaukee,great.
In my opinion,Milwaukee makes some of the best tools you can buy.
I started converting to Milwaukee about 10 years ago.As my old
"Crapsman" tools wear out,(that does'nt take long)i replace them with Milwaukee,and i havent
found a bad one yet.......digger2
2015 Ford F250 Super Duty Extended Cab 4x4 Pickup Truck (A46684)
2015 Ford F250...
2012 STAGECOACH TRAILER MONORAIL (A47001)
2012 STAGECOACH...
New Holland 256 Hayrake (A47809)
New Holland 256...
Vermeer Navigator Directional Drill and Trailer (A44391)
Vermeer Navigator...
Savage 420 Pecan Harvester (A46443)
Savage 420 Pecan...
2018 Isuzu NPR-HD 24ft Box Truck (A44571)
2018 Isuzu NPR-HD...
