Anyone know what sort of link this is?
   / Anyone know what sort of link this is? #11
Not seen one in years but they seemed very common when I was young.....they're used to repair or join chain(s).
Me, too. Haven't seen them for somewhere between 8 and an infinite number of years.
Bruce
I figured it was some sort of repair link. My goal was to find a source for them. Never saw a Menards in this area. Thanks for the tip.
   / Anyone know what sort of link this is? #13
A bud has these two and doesn't know where they came from or what they're called. One is marked "1/4" and the other "1/2". No names, but the 1/2" link has a stylized "A" and a symbol that looks a bit like the Swiss cross. They're handy to use as light duty no-snag clevises.
I have a couple of those in the "junk box."
I think I have seen them in the local hardware store.
By the way, what I have seen others here call a "clevis," I call a '"shackle," or more accurately, a "screw pin shackle" (to differentiate from a "loose pin" shackle)
   / Anyone know what sort of link this is? #14
I guess it depends on where you live. For me it has always been a clevis.
Shackles are for prisoners. :D
   / Anyone know what sort of link this is? #15
   / Anyone know what sort of link this is? #17
On the subject of "clevis," I use what are called "double clevis" connectors (sometimes called "twin clevis") at the tops of the home-brew limit chains on my rotary cutter:
   / Anyone know what sort of link this is? #18
I think if you are on a farm it is a clevis, a left over term from old mule farming days.
If you are talking to a rigger, then it is a shackle for joining or holding together multiple cables for lifting. For heavy lifts, you almost always use a shackle rather than just hooking on the cable loops to the crane. I have seen shackles so big that they need a cherry picker to lift up the pin to go in the shackle and the rigger needs both hands to hold the nut that weighs over 50# to screw on the pin.
NOTE: The larger shackles have a thru pin rather than threaded into the shackle itself.
   / Anyone know what sort of link this is? #19
Another industry where it would be "shackle" would be the marine industry. I spent a fair portion of my youth "laying barge rigging", as shown in this photo from a Coast Guard web site. This is how barges are tied together on rivers/intracoastal (unless the wimps are using winches instead of "hard rigging")
They have a shackle inbetween the "wire" and the "chain links"
EDITED TO ADD: They really don't have that rigging in the photo set-up right, but then it's the Coast Guard and they don't do that sort of thing for a living. There really isn't any reason to have that section of "chain links" between the shackle and the pelican hook of the ratchet- the eye of the wire should be hooked right into the pelican hook. They could have "jerked" that ratchet, or "run it out" a bit if they needed a few inches more slack.
1996 Monon 45X96 Dry Van Trailer (A51039)
1996 Monon 45X96...
2006 INTERNATIONAL PAYSTAR 5500I KILL TRUCK (A50854)
2006 INTERNATIONAL...
2015 MACK GU713 WINCH TRUCK (INOPERABLE) (A50854)
2015 MACK GU713...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50324)
2020 Kubota Z723KH...
2014 John Deere 635F Grain Platform (A50657)
2014 John Deere...
2021 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A50323)
2021 Toyota Tacoma...
