LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,250
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
I do not like to fill tires, my 8050 and 574 do not have filled tires, the 574 doesn't have a loader and being a "light" tractor with very well worn R1 tires it doesn't tear up the lawn. On the farm some of the tractors have filled tires,but the majority do not. We find that with adequate iron bolted on and not having to make one tractor do every thing and having larger one for heavy lifting that we do not need the liquid fill. We do a lot of road work between farms, liquid filled tires will adversely effect the hauling ability, the braking ability, the ride suffers on the road and in fields. Then the major deterrent for use is the cost aggravation and time and equipment to repair a flat when field work has to be done, a plug or a gallon or two of slime type products or if it's a slowleak just airing it up allows the work to get done rather then spending hours pumping down cleaning repairing refilling acquiring more fill liquid and the cost and time of repairing a filled tire if paying to have it repaired is huge. Also there have been members on here that have had the tires spin on the rims when using the beet juice products. I have 1300 lbs of wheel weights on the 8050, the Puma has even more, a couple of the bigger tractor have more and the Magnums have a full front rack and no rear weights and work quite well.
Many members here seem to believe that the tractors can't work without filled tires and are unsafe, maybe theirs are, the ones that I run are capable without liquid fill and it's associated costs including on severe side hills and grades. The only plus for liquid fill is the initial cost after that it's just minus's.
