Anyone use a Dearborn loader on their Ford 8N/9N
   / Anyone use a Dearborn loader on their Ford 8N/9N #1
jgbanshee
PA
JD 310SE, 4300, 5300, 5210, 450 Crawler, CAT D3B, Ford 2N, 5000, 4000su, 3610, 345C, 340B, 1100
I just bought a Dearborn 19-42 loader (jungle gym type) and was wondering if anyone has one or one like it on their Ford N-series. Mine looks to be strong and heavy. I never had a loader on my 2N yet and i am wondering how it will handle it.
   / Anyone use a Dearborn loader on their Ford 8N/9N #2
It will affect your steering. N's with loaders are pretty much powered wheelbarrows. They can scoop uncompacted materials, and maneuer, snow, etc. They are not a digging machine.
As I said before.. steering will be tougher. I suggest you get/make a counterweight for the rear end. Most people just get a big plastic tub or barell, and cut a hole in either side and slide a drawbar thru it, seal the holes with duct tape, and then fill it with concrete, Add a method to hook up the toplink. 400-600 pounds helps alot. Also.. you may find that the skinny 4x19 tires either flatten out under a heavy load, or leave 3" deep ruts whereever you drive. 2 easy fixes, and quite a few more involved ones.
You could get a set of flat or knobby motorcycle tires for the front.. they mount up fine, and you can get them a tad wider/flatter than an oem 3-rib. Second option is to order a new rim.. like a 16" rim, and then you have a wide variety of ag and implement tires that will fit on it. Be carefull. Most implement rims have a small bolt pattern that is the same as the 8n front hub. The 9n/2n has a wide hub, however places like www.just8ns.com DO carry a 16" rim for the 9n/2n.
Other options are to swap out your front hubs with 8n hubs..
Here's a pic of the counterweight I made for my 660 with 1 arm loader.
Soundguy
   / Anyone use a Dearborn loader on their Ford 8N/9N #3
I have a loader that came with my 49 8N. I took it off beacuse I have a loader on my IH 460. I have put it back on a few times to use, I've done snow removal, moving gravel, and other landscaping with it. I've got both sets of rims (16 & 19). Even though it is small - it's a handy thing to have around.
Do the 19 in work ok on a paved driveway?
   / Anyone use a Dearborn loader on their Ford 8N/9N #5
Don't know - mine isn't paved! They might work a little better on a paved surface - I usually run the 16" when the loader is on.
I emailed just8ns and they said that they only carry 19in for the 2N/9N.
   / Anyone use a Dearborn loader on their Ford 8N/9N #7
try valu-bilt in Indianola Iowa. They should have rims for 8N.
I THINK it's: www.valu-bilt.com
   / Anyone use a Dearborn loader on their Ford 8N/9N #8
He's looking for 16" 9n/2n rims.
8n rims are easy to find.
Soundguy
   / Anyone use a Dearborn loader on their Ford 8N/9N #9
</font><font color="blue" class="small">( I emailed just8ns and they said that they only carry 19in for the 2N/9N. )</font>
You know what I was thinking of.. welding the centers for yours into blank 16" rims. That's what alot of people do. that or swap hubs.. etc.
Soundguy
2014 Ford F-250 Extended Cab Knapheide Service Truck (A50323)
2014 Ford F-250...
John Deere 625F Grain Platform (A50514)
John Deere 625F...
10' Poly Feed Trough (A50515)
10' Poly Feed...
2013 Nissan Juke SUV (A50324)
2013 Nissan Juke...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
Barn Wood Bar Table (A50515)
Barn Wood Bar...
