case580c
- Joined
- Aug 27, 2008
- Messages
- 193
- Location
- Northern California
- Tractor
- Kubota M5140 Case 580C, Case 450C, Case 850B John Deere 350C, Kubota L185, Kubota L245H,
Anyone with a B1750 or B1550 when you place the key in the run positon (before turning the key to start engine positon) do any of the panel lites come on? I would guess the low oil and charging lite would come on ???
Tractor will not start. B1750HST-D is the model, panel lights do not come on now when key is turned to the first position (run) and when key is turned to the start position, the engine turns over fine. NO smoke comes out of the exhaust pipe. I suspect that a perhaps a switch is not being activated to allow fuel to supply the injectors? A rodent may have chewed through a wire or grounded a wire? or a component has failed. I have no manuals for this tractor as it belongs to a friend, that has no mechanical skills. Thanks for any help
I am hoping that the manual shut down control is not pushed fully in, But the no panel lites when key is turned to the first position (ON) has me being doubtful. This is a friends tractor that I only operate twice a year that is why I don't recall it lites come on normally in panel or not. Any suggestions appreciated, Thanks
