aprox cost to replace clutch on jd5400
   / aprox cost to replace clutch on jd5400 #11
A&I has good quality clutches for utility tractors and I would not be afraid of them. The difference will be in the warranty, if done at a JD shop with JD parts you get a year warranty parts and labor. A&I you will also get 1 year but be prepared to pay for the bulk of the labor, they do reimburse some labor but it won't be even close to what a dealer charges.
Well called my local dealer - they quoted me a min of 5k guess I will not be going there
   / aprox cost to replace clutch on jd5400 #13
OUCH that's a big bill 5k plus, More like 6k when they get done
   / aprox cost to replace clutch on jd5400 #14
At a dealer charging approx $150/hr it should come up to approx $4,000 for the project with oem parts. Labor rates can vary a lot across the country. Deere's flat rate on this project is 14-18 hours for an open station. For a 5k project with the parts that's over $200 hr but not familiar with your area that very well could be the going rate in MD.
I will have an independent shop do it - that seems really high to me.
   / aprox cost to replace clutch on jd5400 #16
I can not see that it can take 14 - 18 hours to do a clutch ! More like 6 hours !
   / aprox cost to replace clutch on jd5400 #17
Ditto 14 hrs would require a lot of coffee breaks:laughing:
   / aprox cost to replace clutch on jd5400 #18
6 hours????
Not really.
I did mine twice in two years (same tractor - bad replacement clutch).
Took (2 inexperienced guys) 10 hours first time, about 8+30 hours second time. Had to remove loader first, each time
Dealer might CHARGE for 14 hours though.
   / aprox cost to replace clutch on jd5400 #19
When you’re talking John Deere Oem parts, and John Deere labor to install, it’s gonna be more expensive than you first thought.
I would go with an independent shop.
   / aprox cost to replace clutch on jd5400 #20
It's the actual flat rate, now granted many independent shops are probably not going to do all of the steps lined out in Deere rate guide and that shaves off lots of time (and they just don't have the same overhead). But this discussion brings up a great point, always get a quote on the complete project, never ask for the labor rate w/out knowing how many hours they intend to bill you. imao
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
2019 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A53421)
2019 John Deere...
1431 (A57192)
1431 (A57192)
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A55851)
2025 Kivel 42in...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
