Charolais
Platinum Member
- Joined
- Sep 26, 2004
- Messages
- 594
- Location
- south/central Va.
- Tractor
- Deutz Fahr Agrofarm 100, Stoll loader, bucket, forks & root grapple
Doc-Bob,I mount the tank heater on the side of the engine. The intake end of the heater has to be below where you pick up the coolant. I've always used the drain plug for the engine block to connect the intake side to.
The output side runs up to what I call a water manifold along the top of the engine head. Most of those manifolds have a plug at the rear end(front end meaning the water pump). The flow from the tank heater has to have upward flow from the output side. So you can't take a hose over the engine and go back down to connect.
By connecting to the water/coolant manifold you get the engine head nice and warm, so you know what that does for combustion. If it's 10 degree in Feb. the engine will crank like it's July. I had a 574 IH and a 1,500 watt tank heater would put the temp. gauge just like the engine was running.
The tank heater uses barbed fittings and 5/8ths heater hose just like most trucks and cars use. I try and mount as close to the engine as possible so nothing hangs the heater while working the tractor. Tractors with loaders I mount the heater between the loader frame and engine. That protects the heater unit alot.
