Are foot valves prone to stick shut randomly?
   / Are foot valves prone to stick shut randomly? #11
The vacuum from the jet sucks the water thru the valve and when there is constant draw down (vacuum) the lift of the valve is steady.
On the occasion you draw water intermittently turning on/off the hose when the pump is running, the valve will "flutter" without the spring keeping down pressure, and if at that time it is near shut down it wont seat properly and leak down.
Most of the time it will seat without the spring down pressure on the check valve, but not always, depending on the flow at that time.
   / Are foot valves prone to stick shut randomly? #12
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58214)
2014 MAGNUM...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
1986 VIM TACK TANKER TRAILER (A58214)
1986 VIM TACK...
2006 Wells Cargo 16ft T/A Enclosed Cargo Trailer (A55973)
2006 Wells Cargo...
2014 GMC Terrain SUV (A56859)
2014 GMC Terrain...
TRAILBLAZER 325E FL GAS WELDER/GENERATOR (A54757)
TRAILBLAZER 325E...
