Are The Fender Handles Solid?
   / Are The Fender Handles Solid? #1
arrabil
Winterstown, PA
JD 4200 & X475
Howdy. Anyone know if the handles on the fenders are solid plastic? Or are they hollow? I want to drill two holes in them. Anyone see anything wrong with that? Thanks!
   / Are The Fender Handles Solid? #2
No. Tell us how it works and what your project looks like when through. :)
The project is here.
So no means you don't see anything wrong with it? But you don't know if they're hollow or solid?
   / Are The Fender Handles Solid? #4
I suspect they are solid. Pull one off to gauge the weight of it in your hand or weigh it on a postal scale.
I was hoping to avoid taking them off but thats a good idea....
   / Are The Fender Handles Solid? #6
I think mine are hollow. When I squeeze them hard, they seem to give some.
   / Are The Fender Handles Solid? #7
hi arrabil, on my new 3520 the handles are hollow. i just drilled a hole in one to mount a mirror. however they do not look exactly like the handle in your picture. i bought a spare from jd in case i screwed mine up. it only cost $5. hope this helps..............bud
   / Are The Fender Handles Solid? #8
If they turn out to be hollow, and not seemingly strong enough to support the 1/4" (?) bolts through it, I'd consider cutting the handle in two, then shaping a piece of wood (oak for me) to insert into the hollow handle. Glue the wood into the handle and let it set while back on the fender.
Then drill the bolt holes through the wood and the handle to give it much more support. Maybe during the off season, just switch off with a new handle when the blower isn't hooked up.
   / Are The Fender Handles Solid? #9
My 790's handles are solid. You probably don't need to remove them to determine that. Look for a parting line seam which should run full length of the grab handle.
To make them hollow when molding, there would have to be some kind of core in the mold (to keep the plastic out). Then, that core would have to be removed. The only way I can see that being done is by molding two halves and gluing those halves together. That would add cost. Deere doesn't like adding cost.
The attaching studs are probably molded right into the handle, btw.
Now, the grab handles on the 4200-4400 tractors are quite a bit longer then the handles on the 790, but you should have a good idea of what to look for.
hope this helps
Yep Bud, that does help.
Beenthere, both good ideas (wood and blower specific handle). My main concern was standing water in the handle not the strength of it though. I figured if it was hollow I might find another way to mount the controls instead of filling it with RTV.
Mine didn't feel hollow when I squeezed it but I'm gonna do what Roy is suggesting. Tomorrow though. I'm done working for the day...
2024 New Holland T8.410 MFWD Tractor (A55302)
2024 New Holland...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55301)
2017 KINZE...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2015 KENWORTH T270 SERVICE TRUCK (A51406)
2015 KENWORTH T270...
2017 Nissan Frontier Ext. Cab Pickup Truck (A54814)
2017 Nissan...
