Are you a Mulcher or a Dethatcher?
   / Are you a Mulcher or a Dethatcher? #1
Raddad
Michigan
Kubota B7100 & B7610
I’ve seen many posts by people with grass catchers and many by people without and so as I see it we have some mulchers and some who do not mulch. I understand the difference of opinion of these two groups. Removing thatch is something I’ve never done. It seems to me to be a contradiction to mulch and dethach your lawn at the same time. Isn’t dethaching removing all the mulch that’s in the grass decomposing and creating all that great compost?
For someone with a grass catcher dethaching shows a consistency of thought that makes since to me. I can understand people with a grass catcher possibly making some sense out of dethaching their lawns. Dethaching and mulching are incompatible and should not be done on the same lawn. Are you a thatcher or a mulcher? One or the other but not both. Thatchism or Mulchism, pick just one!
   / Are you a Mulcher or a Dethatcher? #2
I am a Mulcher. Most of the time my grass trimmings go right back into the lawn. There are exceptions. Today, I intend to mow leaves. If I have areas where the leaves hide the grass after mowing, I may sweep them up. During the grass growing season, I use the sweeper to pickup grass clippings that are readily apparent (usually from mowing wet or long grass). I have not used the sweeper the last four mowings, since changing to high-lift blades on my mmm. I have thatched my lawn once in the last 35 years (about 25 years ago). My lawn is not a show place, but it is nice. The neighbors' lawns that are nicer than mine both have in-ground watering systems, which mine does not. :)
   / Are you a Mulcher or a Dethatcher? #3
Neither. I'm a cut it and let lay where it falls person.
It was a cowfield and I just started mowing it.
I don't dethatch, mulch, fertilize, overseed, or anything else.
I just mow it. Period.
And I have the best lawn in the neighborhood.
All my neighbors have told me how much they love my yard.
And what do I do to keep it looking so nice. I say I just mow it.
Pooh Bear.
I don't mow the lawn. I do battle with the vegetation.
   / Are you a Mulcher or a Dethatcher? #4
I guess I'm not supposed to answer since you said I can't be both.:rolleyes: When I lived in the city before I retired, I had one of the nicest lawns in the neighborhood. It was never dethatched in the 11+ years we lived there, but I used a grass catcher on the mower. Then when we lived in the country and had nearly 3 of our 10 acres as "yard" (wouldn't necessarily say it qualified as a lawn), I mowed with either the tractor powered finish mower or a riding mower, no grass catcher, no dethatching; just left it where it fell. And now I'm back in town with a small lawn, but I have a little ZTR mower; no grass catcher because (1) they're too expensive, and (2) they're too big to easily store. So I guess you could say I'm a mulcher since the ZTR is set up for that. However, two or three times a year, I tow the dethatcher around over the lawn, then tow the lawn sweeper to pick up clippings and/or leaves.
   / Are you a Mulcher or a Dethatcher? #5
Mulcher only. Too much work to collect the clippings. I fertilizer once a year in late Fall. My lawn grows too well already.
Bob
   / Are you a Mulcher or a Dethatcher? #6
I'm pretty much of the chew it up and spit it persuasion myself. I've also never been a person to get real excited about having an acre or so of monoculture grass all the same exact height and density and then diamond cutting it to win the "best lawn" plaque. My BIL did that once just to tick off his neighbors -- he'd cut it and such when everyone else was at work, using the same skills and equipment he uses at work on the golf course. His subdivision actually does have a rotating sign for the best lawn!
Me? I just mow whatever comes up and hope more of it grows in the wooded pasture area than does in the lawn area. I'll confess to using some grass seed in the past, but not much and only on areas that were either excavated or filled with the dirt taken out from somewhere else. Fertilizer comes from letting the sheep graze the lawn a couple of times each year and chewing up the leaves with the mower in the fall.
   / Are you a Mulcher or a Dethatcher? #7
I cut my lawn at the highest setting. 3 inches tall after it is cut. Looks better, no scalping and tolerates dry weather much better. Also, hides the grass clipping better.
Bob
   / Are you a Mulcher or a Dethatcher? #8
I on the other hand, cut mine as short as the mower will cut. That's for two reasons, first... the height adjuster handle broke and my mower deck is STUCK down at "max low" until I can get the handle welded/fixed. :rolleyes:
The second reason I cut it so short (prior to handle breaking I cut it short, but not AS short) is when we walk the dogs out in the field, I'd return with at worse, the bottom of my pant legs soaked or if grass wasn't 'at length', only dew soaked shoes.
Because of all that, I cut my stuff on the shorter side, not worrying about scalping (after I scalp enough, it should be self limiting?). Nor do I worry about dead spots. Not had any up to now so they just aren't a concern for me. If it got to be a REAL dry spell, the grass wouldn't grow and I wouldn't need to cut it so that balances out (to me).
:D
   / Are you a Mulcher or a Dethatcher? #9
I've been a mulcher ever since they became fairly widely available. They also do a good job on leaves.
Have used a dethacher if the grass looks kinda ratty, not the case since moving here and doing regular mowing at high height (about 3-3.5"). Mowing high leaves more space for the clippings to dwell without becoming a problem and shades out a lot of the low-growing weeds. Many weeds will disappear if you mow them before they seed. Grass will then take over.
Ralph
   / Are you a Mulcher or a Dethatcher? #10
Richard, my parents live in Knoxville, and like you, I used to cut their grass pretty short there - maybe 1 1/2 inches? Plenty of rain, and fairly moderate summer heat...
But here in the Dallas area, with the summer droughts we've been having, I mow at 3 inches - when I'm lucky enough to need to mow. We've had so little rain that the entire 2 acres is nearly dead, except next to the foundation, where we water to keep the slab from cracking... And of course, the hardiest weeds that still seem to sprout in the middle of the dead sea of grass... :mad:
But to the OP, I always mulch - never dethatch. When it's not "dead" from lack of rain, it looks pretty darn good! I mulch the leaves in the fall, also.
2018 Toro Groundsmaster 7200 72in Zero Turn Mower (A44572)
2018 Toro...
2014 Ford Taurus AWD Sedan (A44572)
2014 Ford Taurus...
Rhino 15ft Batwing Bush Hog (A44391)
Rhino 15ft Batwing...
2022 John Deere 1025R Tractor (A44391)
2022 John Deere...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A44572)
2022 Chevrolet...
4Yd Dumpster (A44571)
