Rotary Cutter Are your rotary cutter blades free swinging?
   / Are your rotary cutter blades free swinging? #21
Ah yes, 1 11/16" nuts, probably the only application for such in the known universe. Had to a difficult time locating the appropriate 3/4" impact wrench socket - ACE Hardware stocks them. And yes, an angle grinder is a bit loud when you're wedged under a brush cutter while working on the blade edges.
   / Are your rotary cutter blades free swinging? #22
Bill, I used to block up my cutter before I got a tractor with an FEL, but now I always lift it up and lean it against a tree. Like you, I've never had any leakage. I believe the filler/vent was on top when I tilted the cutter up, so it was never in fluid.
I've never had my blades stick like yours. I think the combination of how long it sits between uses and the amount of humidity trapped under the deck might contribute to the sticking blades. I've sure started the cutter turning a few times with the blades partially stuck and had the cutter do a "dance" until it got up to speed, and centrifugal force put the blades into the correct position. /forums/images/graemlins/smile.gif
   / Are your rotary cutter blades free swinging? #23
Yall make me happy that I have airtools! /forums/images/graemlins/laugh.gif
2009 Ford F-250 Ext. Cab Enclosed Service Truck (A53422)
2009 Ford F-250...
2015 Ram 5500 Versalift SST-40NE 40ft Sign Bucket Truck (A55852)
2015 Ram 5500...
2009 FREIGHTLINER M2106 26FT BOX TRUCK (A56138)
2009 FREIGHTLINER...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
TRAILER MOUNTED WATER PUMP (A55745)
TRAILER MOUNTED...
