Oil & Fuel Arggh, BX2200 fuel tank leaking
   / Arggh, BX2200 fuel tank leaking #1
upgw
SE PA
2001 Kubota BX2200, 2011 Hustler Super Z 31 Kawi
Well, it finally got me. Since my BX2200 was a later model (picked it up last September), and had the grease fitting on the pedal, figured the tank was fixed as well (dealer said it was). Just noticed I have a steady drip of fuel onto the rear of the left rear tire (as viewed from behind)... guess I'll be calling the dealer tomorrow.. arghhh.
- Patrick W.
   / Arggh, BX2200 fuel tank leaking #2
Add my BX2200 to the list of leaking tank, picked mine up March 2002,was assured it was fixed by the dealer, well guess what??, its going back next week to fix the leak, same place as yours, I HOPE this is not an indication of a lemon for a tractor???
Tom
   / Arggh, BX2200 fuel tank leaking #3
don't that just tick u off?/w3tcompact/icons/mad.gif a problem like that, that has been known for awhile should not be still showing up. hope they get it fixed post haste.
   / Arggh, BX2200 fuel tank leaking #4
What do you mean by that?
I have had my 2200 for about 2 mo's., 76 hours on it. No leak yet, just trying to understand about the zirc on the pedal.
Thanks,
Hootie
   / Arggh, BX2200 fuel tank leaking #5
If you are sitting on the seat, on the left side of the pedal, look real close and you will see a zirc. In older models the pedal would stick down when you take your foot of the pedal. So they put a zirc fitting in, it is NOT in the operator’s manual, well at lease not in mine . I have a problem where the fitting will not take grease, so they will be looking at that too.
Tom
See Tom's post for the details, I have the zirc on the left side of the pedal pivot, very hard to get grease into, and the pedal is sticking anyway. I think there is another thread which indicates that the 'pedal' is sticking elsewhere, not at the pivot. I'm going to ask the dealer to look at that as well, they are coming tommorrow to get the tractor. They seem to think it's the fuel guage attachement to the tank.
- Patrick W.
   / Arggh, BX2200 fuel tank leaking #7
I'm the one that started that thread [click here=http://www.tractorbynet.com/cgi-bin/compact/showthreaded.pl?Cat=&Board=owning&Number=162059&page=&view=&sb=&o=&vc=1#Post162059]. Breakfree sprayed on the control shaft entering the transmission fixed the problem.
   / Arggh, BX2200 fuel tank leaking #8
Well, the first time on the url thing didn't work. maybe this time. <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showthreaded.pl?Cat=&Board=owning&Number=162059&page=&view=&sb=&o=&vc=1#Post162059>click here</A>
   / Arggh, BX2200 fuel tank leaking #9
Not to worry, the fuel tank repair is fairly simple and should be the only problem you encounter with the BX. Good Luck...Tractorman
   / Arggh, BX2200 fuel tank leaking #10
Yea that is if they have the part, my replacement tank been back ordered, going on 3 weeks! Guess this must be a REAL problem if they can not keep tanks in stock! Good thing the grass is dead since we have had no rain in a while.
Waiting for a tank in NJ......
Tom
2020 CANYCOM SC75 STAND ON DUMP BUGGY (A51246)
2020 CANYCOM SC75...
Rhinox Mechanical 40 mm Coupler (A52384)
Rhinox Mechanical...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A51248)
UNUSED WOLVERINE...
0375 (A51694)
0375 (A51694)
