Erik_in_Hoyt
Platinum Member
.308 and 30-06 fmj will drill through 1/2" hot rolled steel.
they will crater 5/8" "tool surface" hardened 4140.
angling your backstop does 2 things: first it increases the cross sectional thickness of the material - which means you can use lighter gauge steel to give an equivalent stopping power as a thicker piece (so at 45 degrees slant, .375" plate will react to the bullet as if it is .5375" thick). Second, putting the steel at an angle to begin with helps "aim" the ricochet, thus lessening your chances of getting hit with a bounce-back.
Hardening the steel makes it more resistant to dimpling or cratering -- which helps keep the ricochet pattern predictable.
