ASV 4810 electric trouble
   / ASV 4810 electric trouble #1
Bison
Platinum Member
Near Peace river -Alberta
ASV 4810
I blew the rad clean with the pressure washer I covered the front of the engine with a piece of plywood so the engine stayed dry, no water entered the engine compartment.
All gauges where working prior to the rad cleaning.
This morning none of the gauges in the cab worked at fire up,only the amp gauge worked.
All fuses are testing good
I can't make head nor tails out of the wiring diagram, it's about as complicated as a computer.
Where do i start looking????, i am stumped
   / ASV 4810 electric trouble #2
Could you have "bumped" a wire installing the plywood shield?
2019 INTERNATIONAL 4300 26FT BOX TRUCK (A45677)
2019 INTERNATIONAL...
2022 Deere 331G (A47307)
2022 Deere 331G...
Case 580B 2WD Tractor Loader Backhoe (A47809)
Case 580B 2WD...
Rears 500 Gal Orchard Sprayer (A47307)
Rears 500 Gal...
2021 CAT 299D3 XE (A47001)
2021 CAT 299D3 XE...
Case International MX Magnum Tractor Cab (A47809)
Case International...
