asv rc 100 skidsteer arms raise slow
   / asv rc 100 skidsteer arms raise slow #1
nahtan33
Asv Rc100
2011 ASV RC100 lift arms raise slow has anyone had this problem. all other loader fuctions work properly
   / asv rc 100 skidsteer arms raise slow #2
Rpms up?
hydraulic fluid level full?
yes hydro is full, running at full throttle. Have replaced the filters and the lift arms cus one was bad and the new ones are not interchangable with the old ones. All my pressure tests were in spec. i have also replaced the joystick with known good joystick and nothing changed. the loader control valve spool moves in and out smoothly. the only function that moves slow is the lift function.
   / asv rc 100 skidsteer arms raise slow #4
Were they lifting slow before you did all of those changes (or is that the reason you did those changes)?
that is the reason i did those changes
   / asv rc 100 skidsteer arms raise slow #6
This isn't your identical issue, but maybe it will help somewhere.....
Thank you i will take a look and see if its something that will help me
202475 (A54757)
202475 (A54757)
1203 (A58374)
1203 (A58374)
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
2007 CHEVROLET KODIAK C4500 (A58214)
2007 CHEVROLET...
Stanley Hydraulic power pack (A56435)
Stanley Hydraulic...
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
