ASV RC100 turning problem
/ ASV RC100 turning problem #1
time out
Ocala,Florida
ASV RC100
Our RC100 is slow to respond when turning left. Line pressures seem proper, and engine RPM makes no apparent difference. Once left turn engages the unit runs true. Makes no difference whether forward or reverse the slowness of initiating left turn is same. I believe problem is a sticky shuttle valve in joy stick base or at transmission. Not sure which. All other hydraulic functions are completly normal and zero issues.
/ ASV RC100 turning problem #2
Easy fix 90% of the time id say it's a resolver block in the joy stick. Does the reverse alarm come on at weird times or do you have one? if not the resolver block then I'd say a drive motor fell free to give us a call if you have questions. Ty would be the best person to talk to.
Hope I helped.
Dave Kopp
Thanks for the return info Dave. As per my follow up call to you, we will be in touch next week, once we reassemble both track assemblies. Gary Ackerman
/ ASV RC100 turning problem #4
Can anyone help me out. I'm having the same exact problem
