At Home In The Woods
   / At Home In The Woods #4,721
Dirty logs will do it every time. Not that I have, but I have thought it would probably be worth it to keep a whisk broom handy to brush off the dirt before cutting. Gloves leave a lot in the bark crevices.
I do save my dirty cuts for last as much as possible. If logs are laying on dirt, I will make the cuts on the clean sides all along the logs, then roll them over and finish the bottom cuts. That way, 90% of your cutting is done with a sharp chain. Sometimes, you just have to stop and sharpen, it will extend the life of everything, as mentioned.
   / At Home In The Woods #4,722
My dirt/clay mix is tough. I carry a wire brush to clean logs. Even then, I try to cut only to the bark and let the bucked end fall off of it's own weight without going into the dirt encrusted heavy oak bark. I still touch up my saw at every tank full of fuel and it seems to take less time each time I do it. I get a lot of cuts with a full tank and a sharp chain, even in my oak.
   / At Home In The Woods #4,723
A wire brush would be handy. Some of the logs in our pile are very dirty. A wisk broom would have trouble cleaning the wet dirt off the part of the logs that are on the ground.
Obed
   / At Home In The Woods #4,725
For real dirty logs I always pressure wash them before milling. For my firewood logs I try not to drag them through the dirt behind the tractor and only use the FEL, but sometimes you just have to do it that way.
Taking the time to swipe the cutters every tank of fuel makes a huge difference when cutting dirty wood.
Obed if your going to cut this much wood every year I'd like to spend some more of your $:
Northern Industrial Bench- or Wall-Mount Chain Grinder | Chain Saw Sharpeners, Maintenance Repair| Northern Tool + Equipment
The wheels are kinda cheap/soft so I replaced them with Oregon wheels but the one's that come with it will last you quite some time.
Then a stump vise for sharpening in the field:
Northern Industrial Stump Vise for Sharpening Chain | Chain Saw Sharpeners, Maintenance Repair| Northern Tool + Equipment
Anything else I can help you with?:laughing:
M7,
Yes, I have my eye on that chain sharpener. I'm not in a hurry though. I'll first see how well hand sharpening and occasional professional sharpenings go. I definitely need a vice for sharpening onsite.
My next big purchase is going to have to be a lawnmower. I think the hydrostatic transmission is going out on my old Kubota mower.
Obed
M7,
Obed
I started working on splitting wood that we bucked up last week. The plastic pipe in the middle of the round stack is supposed to help get air moving in the middle of the stack. Supposedly it acts like a chimney to move warm air up through the middle as the pile dries.
Today I started using the splitter in vertical mode when I got to some big log pieces. I took ClemsonFor's suggestion and made myself a seat to sit on while splitting. ClemsonFor suggested a bucket; I made a seat out of a log. Wow! I have to say that sitting on my behind while splitting wood was great. My back loved me for it. My back gets tired when bending over the splitter in horizontal mode. I like sitting on my behind! While sitting one the log seat, I just tossed split pieces onto the pile. After thowing a bunch of logs on the pile, I would turn off the splitter and stack the logs. Then I would split some more.
I'm liking the round stack. It's quite handy to be able to throw the odd shaped or short pieces in the middle. It's also nice to not need to stack over half the pieces. I have just under 2 cords in the round stack so far.
   / At Home In The Woods #4,729
Have you thought about just getting a mower for the JD? One less engine to maintain...
Looks like you are getting nicely ahead on your wood cutting now!
Pull Behind Wood Splitter (A57453)
Pull Behind Wood...
2005 Suzuki King Quad 700 Fourwheeler (A57453)
2005 Suzuki King...
North Star VR-344 (A57148)
North Star VR-344...
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
1998 CAT 140H Motor Grader (County Owned, Cat Maintained) (A59213)
1998 CAT 140H...
2 Tires and Rims (A57454)
2 Tires and Rims...
