At Home In The Woods
   / At Home In The Woods #5,721
Coyote,
Good question. If I need to remove the stump, it's faster to drop the tree with attached stump with the backhoe than to use the chainsaw first. Pushing the tree over while it is still attached to the stump uses the weight of the tree to pull the stump and remaining roots out of the ground. Digging a stump out of the ground by itself requires a lot more digging and is time consuming, especially if there are roots directly below the stump. Also, taking the tree down with the backhoe gives you a lot of control over the direction the tree falls.
The cable was attached to the trunk about 15 feet high. It was only a safety for just in case the tree wanted to fall backwards instead of forward while I was digging on the backside of the tree. It probably wasn't necessary. Most people wouldn't use it under most conditions. However, I was just being extra cautious because I have very little experience taking down trees with a backhoe (or with a chainsaw).
If I had dropped the tree with my chainsaw, I probably would have hooked up the cable anyway, again because of my lack of experience. I have never dropped a tree as large as that maple with a chainsaw. I'm more comfortable trying the bigger trees with the backhoe than the chainsaw. Eventually, I may work my way to dropping a tree that large with my chainsaw. If I don't mind leaving the stump in the ground, dropping the tree with the chainsaw would be faster than using the backhoe.
Obed
Obed, I get what you were trying to do, however I believe your lack of experience with chainsaws and 'bigger' trees in combination with using your tractor hoe actually puts you in greater danger than using proven tree felling techniques. The dig out the stump, have it rip out when the tree falls works in theory but the possibility of the tree going wrong when pushing on it makes anyone who does tree work, or has done tree work for a living cringe. The possibility of the tree top / tree 'barber-chairing' is always a possibility, which could drop the tree on the tractor operator, with no time to prepare or escape serious injury/death, is a not uncommon force to be avoided at all costs.
FWIW, I am enrolling in a multiple stage forestry course, which covers ALL aspects of tree felling, chain saw use and maintenance, and much more, at the higher level stages. It's called: "Game of Logging", and may be available in your area. I found out about it coincidentally on TBN and signed up for the 1st two sessions after reading about it. Though I have years of experience working with trees, saws, etc., one can always hone one's skills and learn new or different ways of doing tree work to improve safety and knowledge. Most prior participants say the techniques they learned are now the only ones they use to fell trees; even highly experienced guys say the same; so that was a good enough endorsement for me to sign-up.
I suggest checking it out on the web, and in person if available in your area.
Stung by a Wasp
Yesterday evening, I got stung by a wasp while trying to attach the scraper blade to the 3PH. Wasps had build a nest inside the implement and I got stung on the back of my right hand through the glove I was wearing. I'm surprised it took the wasps as long as long as it did to nail me. I had moved the blade around on the ground for quite a bit before I got stung. Normally I will immediately put ice on a bee sting to reduce the effects of the poison. However, I had a lot to do before the impending rain arrived so I didn't use the ice.
I got some wasp spray and sprayed inside the hollow part of the implement. I then swatted wasps with a broom and sprayed in the air to kill about 3 of them. Finally, I attached the blade to the 3PH while one remaining mad wasp that I couldn't kill flew around.
I put my gloves back on and continued my work. By the time I went to bed, my hand had started swelling. When I awoke this morning, the hand was more swollen. Today by about 5 PM, my hand was looking pretty bad so I wend to a walk-in clinic. They prescribed 7 days of steroids. The nurse practitioner told me for signs to look for that might indicate an ER visit would be needed.
Normally, I don't react this badly to a bee sting. Yesterday evening, while working, sometimes my right hand felt like something was stinging my again but I ignored it and kept working. I am now wondering if the stinger was still in the glove and I was getting multiple ongoing stings from the stinger. It's just a hypothesis. In addition, I bled some where the wasp stung my hand. I suspect the stinger and poison penetrated a vein.
Have you ever tried spray on Benadryl, or the liquid for treating bee stings? I try to use it right after the sting to neutralize the effects of the poison, and alleviate pain/swelling.
CM. (Note, my text in blue above.)
I took steroids and Benadryl for one day and the swelling and temperature in my hand went way down. I stopped taking the steroids after the first day. The clinic prescribed 7 days of steroids. However, once it was apparent that I was past the danger stage, I stopped taking them. I'm not terribly fond of ingesting foreign substances into my system.
The task I had to do on Monday evening when I got into the wasp nest was to finish smoothing out the ground where the shed would go. That's why I was attaching the scraper blade to the tractor when I got stung.
IMG_0549.JPG IMG_0551.JPG IMG_0552.JPG IMG_0553.JPG IMG_0555.JPG IMG_0556.JPG
   / At Home In The Woods #5,726
Garden Shed
The rental house has a 10' x 15' metal shed on the lot. We are going to move that shed to our house near the garden. There was a 55 ft tall maple tree at the spot where the shed is going to be located so I had to take it down. I was a little nervous about taking down this large of a tree with my little backhoe.
Putting on the backhoe.
View attachment 382703 View attachment 382702
Here's where the shed will go.
Moving some rocks out of the way.
I would not move that shed from the rental. If you want one at your house, buy another one.
I speak from experience, I once bought a rental house with a shed. Cleaned out the house, and the shed and rented it. With two months the tenant had filled the shed with enough "stuff" that he could no longer even think about moving somewhere else. The "stuff" that would have cost maybe $250 at a garage sale, was like putting a ball and chain around his foot. There just aren't many rental houses with lots of storage available.
The first tenant never really moved out, he died in the driveway after 12 years of renting it. His wife got his kids to move the stuff out of the shed before she moved out. The next tenant had the same "excess stuff" problem. He stayed 8 years with no thought of moving out, again because of the stuff he had. I sold the house when I moved to OR. There was a substantial profit on the house and I paid the tenant $2500 to move out on my schedule instead of his. He moved out right on time with no problem.
Anyway, that shed is your best friend if you are looking for long-term tenants.
   / At Home In The Woods #5,728
Just goes to show....I had the exact opposite experience...One of my rental houses had a 30X48 storage building....Every tenant I had loved the storage and when they left in the night usually...they left me with at least a roll off or two worth of their garbage...Other tenant houses I had with no storage...never presented that parting cost of removing the tenants junk.....The storage building might be an asset renting the house but be prepared to empty the junk when the tenant leaves.....usually in the middle of the night....:2cents:
   / At Home In The Woods #5,729
there is nothing like watching and hearing a 20+" tree that you dropped hit the ground! Love having to use the MS650 with the 25" bar to drop trees!!
   / At Home In The Woods #5,730
call a donation place and let them pick up the "junk" then just toss the rest, saves the cost.
2006 Mercedes-Benz Unimog 405 4x4 Flatbed Truck (A56858)
2006 Mercedes-Benz...
Giyi Mini Backhoe (A57149)
Giyi Mini Backhoe...
Mini Skid-Steer Land Leveler (New/Unused) (A59225)
Mini Skid-Steer...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
2013 MACK CHU613 (A58214)
2013 MACK CHU613...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
