At what temperature do you need to plug in a tractor?
   / At what temperature do you need to plug in a tractor? #31
This got me thinking............... Is there such a thing as this or could one of you electrical savvy people invent a remote switch to turn on the block heater and automatically turn off after say an hour ? You could activate it with a garage door opener............ If you make many millions $ on this idea said:
well you could use "THE CLAPPER" :)
   / At what temperature do you need to plug in a tractor? #33
I plug mine in when I get up at 6 AM if the temperature is in the 20s or lower, and I need to move snow.
It's warmed up by the time I've done my business in the bathroom, had breakfast and my coffee.
   / At what temperature do you need to plug in a tractor? #35
Even though I have a radiator hose style heater in my tractor, I have never used it as I don't have power in the building I keep the tractor in, nor is it heated. I have started the tractor in temps as low as -22dF, just cycled the glow plugs several times and it started right up. I let it idle for a minute before I moved anywhere, then worked gently until temp meter moved.
   / At what temperature do you need to plug in a tractor? #36
I have a heavy duty timer rated in excess of the wattage of my block heater. Used it often when I had 2 daughters driving to college, cars for both my wife and me to drive to work, and only a 2 car garage. Now they have long since graduated, its just my wfie and me, and a 5 car heated garage. That HD timer is somewhere around - most of the timers I see now will handle Christmas lights and that's about it.
   / At what temperature do you need to plug in a tractor? #37
MY block heater doesn't draw a whole lot of amps. The problem I ran into (heating my tractor as well as a small plane) was that a number of the cheaper timers won't work when the temps really get cold.
   / At what temperature do you need to plug in a tractor? #38
Thats impressive. What oil do you use?
larry
   / At what temperature do you need to plug in a tractor? #39
The 2 tractors that load hay and grain are plugged in for several days even weeks at a time as you never know when trucks will turn up for a load .
The rest sit in a shop without power till spring .
   / At what temperature do you need to plug in a tractor? #40
For reliable remote switches I use a Z wave switch. Range seems to be around 100', but if you have multiple devices they will relay the signal, so you can chain them and get a longer range. I use one to control switches in my garage and workshop, which is detached from the house. I just use it for lighting and to turn on an electric heater before I go out to work in the winter, but it would be easy enough to wire it up to an outlet for a tractor heater. There's a wide variety of controllers and switches that use the Z wave standard and they're not too bad to setup.
2010 Kaufman Gooseneck Trailer (A59814)
2010 Kaufman...
Cub Cadet SLTX1050 Riding Mower (A59814)
Cub Cadet SLTX1050...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2020 Ford F-250 Ext. Cab Service Truck (A59230)
2020 Ford F-250...
Stout Brush Grapple (A59814)
Stout Brush...
Sterling 9500 (A56438)
