attaching MMM to B7500
   / attaching MMM to B7500
I think the rear arms are all the way down about 5" from the ground. I have stepped on them and they wont go down any further. Do you mean trying to put weight on the arms under the tractor? I have been looking at this for hours and I am getting no where. All the posts I read about problems with MMM seam to be related with the splined shaft connecting to the drive shaft. I had no problem with that it went on in 30 seconds. Your replies are appreciated.
Thank you everyone for the replies. I was frozen. I had the neighbor push on the back and I pulled on the arms from underneath and it finally gave way. Thanks again.
Mike
   / attaching MMM to B7500 #13
Glad you got it fixed.
The arm just behind the gold bracket for holding arms up when MMM is not on. Has a grease fitting on my MMM. Check yours, it may need some grease.
   / attaching MMM to B7500 #14
Glad you found the problem. Nothing more frustrating than things not working when you want them to. I used the rainy day today to do my 100 hour service. Was all set with my oil and filter etc. Drained oil, removed filter, open new jug of oil and find the tamper seal broken. Pause to think then decide no way I am going to risk that someone put something in it and damage my baby. So clean up and off I go back to Wal-Mart for an exchange (Rottella T Synthetic).
These things never take the 1/2 hour they are supposed to. Oh well it's still just "work" on the tractor /forums/images/graemlins/grin.gif
Good luck with your mowing, I'm all ready to do mine now as well. Everything is ready to rock and roll.
2011 PETERBILT 384 TANDEM AXLE TANKER TRUCK AND TANKER TRAILERS (A54607)
2011 PETERBILT 384...
JARRAFF TREE TRIMMER (A52706)
JARRAFF TREE...
2024 New Holland T8.410 MFWD Tractor (A55302)
2024 New Holland...
2021 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A53422)
2021 Chevrolet...
2014 Ford F-350 4x4 Cab and Chassis Truck (A53422)
2014 Ford F-350...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A54814)
2003 Pierce Tilt...
