Attaching PTO Shaft Newbie Question
   / Attaching PTO Shaft Newbie Question #1
2kpsd
Martell, NE
Montana Limited 300DTC
I am borrowing a PHD from a friend at work to put up some corner posts for my horse fence. It is just like one you buy from TSC. I'm having problems connecting the pto shaft to the tractor. It slides on an inch or so but thats all. This is the first time I'm using the pto. He told me I might have to take a wire brush to the tractor side of it because it is brand new, never used and still has paint on it. The PTO shaft has a locking collar on it but I could not get it all the way locked on. Any suggestions or am I doing something wrong???
   / Attaching PTO Shaft Newbie Question #2
It sounds like you are not disengaging the locking mechanism on the PHDs shaft. You need to release the bearings that lock into the groove on your tractor's PTO. I can think of three different systems offhand. One of them looks like you would turn a collar to release it, but you need to pull the collar back.
Either way, when you think you have it locked on, make sure you give it a few good tugs to make sure.
Yes, I tried with the collar pulled back but it still wouldn't go fully on.
   / Attaching PTO Shaft Newbie Question #4
All I can say is that if you can get it started, like you said, it is probably getting hung up when the bearings encounter the tractors PTO. Hold the PHD's PTO shaft up and see what you need to do to get the balls to release. Maybe they're "frozen" in place even.
This topic has come up before and it is usually a case of not doing what is necessary to release the steel balls.
You could always ask the guy who lent it to you, too. Maybe it's broken and he wants you to fix it /forums/images/graemlins/tongue.gif
Good luck
   / Attaching PTO Shaft Newbie Question #5
Sounds like you are not getting it slid on far enough.
If you are getting the PTO to slide on about an inch, and then when pulling the collar back, not getting the PTO to slide on another inch, that is the problem.
Look at where the groove is on the PTO drive shaft and where the 'balls' are in the PTO shaft. That is how far you need to move on the drive shaft. When far enough on, then the balls should engage and lock the shaft onto the tractor.
Just sounds like you are not going far enough, and I would first suspect the tractor drive shaft needs cleaning of paint, as the PHD owner suggested. Also, look for any burrs that might be holding it up.
   / Attaching PTO Shaft Newbie Question #6
You cleaned off your tractor shaft spline? And it's borrowed? Check the shaft end for any mud or crap that might be in there?
   / Attaching PTO Shaft Newbie Question #7
I had the same thing happen to me,I tried shaking and everything that I could think of including levering with a bar. Then it just slid on with no effort at all,very confusing. Maybe the balls have to aline with spline also, I still haven't figgured it out. Just have to have blind determination I guess.
   / Attaching PTO Shaft Newbie Question #8
Check to see if the balls are loose when the collar is pulled back. If it has been setting for a long time they may be just stuck.
Thanks everyone for the replies - I am going to try spraying the pto shaft with penetrating oil tonight to make sure the balls are free and not stuck. See what happens from there-
   / Attaching PTO Shaft Newbie Question #10
I had this problem as well- and it turned out the PHD shaft had a plastic collar that I could move, but that wasn't the acutal locking mechanism- you need to actually grab the end of the PTO connection (not the little plastic collar that moves) and either slide it forward or backward (different shafts go different directions) to unlock the bearings so you can slide it all the way on. I still screw it up as my mower is a pull back then slide the shaft, and my PHD is a pull back and then slide on the shaft- drives me nuts.
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
2016 Ford Fusion Passenger Car, VIN # 3FA6P0G79GR191653 (A50324)
2016 Ford Fusion...
2015 Ford F150 Crew Cab Pickup (A50323)
2015 Ford F150...
2014 Chevrolet Tahoe (A50324)
2014 Chevrolet...
UNUSED AGT QK18R EXCAVATOR (A51243)
UNUSED AGT QK18R...
