Attaching the BH OR My 1966 shelf
   / Attaching the BH OR My 1966 shelf #1
Dewave
Soloman\'s Island, MD
CK20HST TLB
As promised here are some shots of the procedure.
Front subframe attachment on the tractor
Rear subframe attachment on the tractor
Top link has to go
Back str8 over the subframe, str8.... straight straight and then hook up the hyd lines
don't overlook this little baby, it can be easily hidden in all the hoses/cables--- Hydraulic switch
with hyd lines connected lift up the BH with stabilizers and boom
now back up some more to see how well you are aligned, make adjustments if necessary.
once aligned just back up a little more and sha-bam
Drop the pins in the rear subframe mounts and your....
.... done
PENDING SELLER CONFIRMATIONS (A52141)
PENDING SELLER...
2015 KOMATSU PC170LC-10 EXCAVATOR (A50458)
2015 KOMATSU...
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
2018 CATERPILLAR 289D SKID STEER (A51242)
2018 CATERPILLAR...
Case Ih 1660 Combine (A50514)
Case Ih 1660...
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG Skytrak...
